Coil Wiring Help!
19 replies to this topic
#1 lewiskestell
lewiskestell
  • Validating
  • 42 posts
Posted 19 May 2012 - 01:11 PM
when tiding around me engine, all the wires off the coil have fallen off due to corroded wires.
I have tried to put them back on but i think they are on the wrong way because the coil isn't sparking when i put a spark plug directly on.
The engine is a metro 1275, does anyone know what wires from where and what current should should be flowing and on to which side of the coil. any help is much appreciated.
#2 lewiskestell
lewiskestell
  • Validating
  • 42 posts
Posted 19 May 2012 - 01:45 PM
anyone? Please?? :P
#3 Jamieboy
Jamieboy
  • 60 posts
Posted 19 May 2012 - 01:48 PM
I just had a quick look at mine and the wires connected to the "-" side have black stripes. As your's is a metro engine, I cannot guarantee they're the same, so it's at your own risk!
Edited by Jamieboy, 19 May 2012 - 01:49 PM.
#4 lewiskestell
lewiskestell
  • Validating
  • 42 posts
Posted 19 May 2012 - 02:27 PM
i have got it running, with a 12v to the positive, and the two wires off the side of the distributor to each side of the coil, but it runs like utter crap :( it ran perfectly until the wires fell off the coil :/
#5 Ethel
  • 26,029 posts
Posted 19 May 2012 - 02:36 PM
Oops,
I saw others looking so figured they'd reply.
The wires come with the car, as long as your coil matches all will be well.
As above, the white with black stripe go on the the negative coil terminal and connect it to the distributor. There might be a 2nd white/black for a rev counter.
The positive side varies, are there any markings on the coil "ballasted", "12volt", "electronic"....?
You might have plain white wires or white with pink or yellow stripes, tell us which.
Just seen your reply,
Iis it Lucas electronic ignition? Dizzy cap held on with screws & a black box on the side?
#6 lewiskestell
lewiskestell
  • Validating
  • 42 posts
Posted 19 May 2012 - 02:56 PM
just been out to take some pictures
the distributor:
Attached File  P1020548.JPG   65.89K   90 downloads
the coil:
Attached File  P1020549.JPG   78.12K   104 downloads
the terminals on the coil, i remover the rev counter, the only wire on at the moment is a constant 12v live and two wires from the side of the distributor
Attached File  P1020550.JPG   51.56K   69 downloads
#7 lewiskestell
lewiskestell
  • Validating
  • 42 posts
Posted 19 May 2012 - 03:20 PM
i have been playing with the wires and nothing seams to help the situation all plugs are sparking it just still runs like crap
#8 Ethel
  • 26,029 posts
Posted 19 May 2012 - 03:44 PM
Well it's certainly a 65dm4 electronic dizzy, so you need a gcl143 coil ,if that's dbl105 I can make out it's the wrong coil for it.
#9 Jamieboy
Jamieboy
  • 60 posts
Posted 19 May 2012 - 03:50 PM
.....The wires come with the car, as long as your coil matches all will be well....
Silly me, quite right!
Definitely nothing else has been changed? Firing order? plugs? (perhaps check condition).
#10 lewiskestell
lewiskestell
  • Validating
  • 42 posts
Posted 19 May 2012 - 04:26 PM
it is a dbl coil, i took it to mini spares they looked at the car to determine the right coil. the car ran perfectly on thursday, i wrapped the wires in electrical tape and that is when the terminals fell of the coil, now she sounds like a tractor :P after guessing and power probing various wires, it is running on all cylinders just really poor
#11 lewiskestell
lewiskestell
  • Validating
  • 42 posts
Posted 19 May 2012 - 04:57 PM
the only thing i did was wrap the wires in electrical tape to try tidy it up a little, i thoroughly regret that choice :P
#12 lewiskestell
lewiskestell
  • Validating
  • 42 posts
Posted 19 May 2012 - 05:35 PM
what wires and current should be going to each side of the coil? i don't know what else could be wrong. dont suppose anyone has a coil wiring diagram???
#13 leroy26
leroy26
  • 2,239 posts
  • Local Club: minisunleashed.com
Posted 19 May 2012 - 05:45 PM
knocked a ht lead off?
#14 lewiskestell
lewiskestell
  • Validating
  • 42 posts
Posted 19 May 2012 - 05:55 PM
nope checked and double checked that all :)
#15 leroy26
leroy26
  • 2,239 posts
Posted 19 May 2012 - 06:04 PM
could be a coinsidence then that the condensers had it
