Mini Cooper Mk1 (Innocenti)
55 replies to this topic
#31 Cooperman
  • 23,565 posts
Posted 23 May 2012 - 07:01 PM
Yes, it does appear to be an 850 engine.
#32 ludiluka
ludiluka
  • 41 posts
Posted 23 May 2012 - 07:04 PM
But is it mini cooper ? was the engine changed ?
#33 jaydee
jaydee
  • 8,565 posts
Posted 23 May 2012 - 07:05 PM
Sorry just to be more precise, its a late austin morris 850 engine, so its possible they've changed the engine.
Edited by jaydee, 23 May 2012 - 07:07 PM.
#34 jaydee
jaydee
  • 8,565 posts
Posted 23 May 2012 - 07:18 PM
Your chassis number is from an early 998 innocenti cooper Mk1.
http://www.miniminor...e_innocenti.htm
#35 ludiluka
ludiluka
  • 41 posts
Posted 23 May 2012 - 07:22 PM
well this will be a quick project because chasis is rust free :) this was my last project Posted Image
#36 ludiluka
ludiluka
  • 41 posts
Posted 25 May 2012 - 12:04 PM
Hi there
i took the cilinder head of the engine today. Head Nr: is 12g295 and cilinder diameter is 64mm.
Is the engine 850 or 1000ccm ?
#37 jaydee
jaydee
  • 8,565 posts
Posted 25 May 2012 - 01:49 PM
998 cc
(Or an 850 with 998 pistons..)
Are pistons flat tops or D shaped?
#38 Spitz
Spitz
  • 1,716 posts
Posted 25 May 2012 - 02:52 PM
848 stock bore is 62.9
998 stock bore is 64.58
From the attached engine tag...it's an 848, and as someone mentioned a 295 head would be proper for an Inno 848
#39 ludiluka
ludiluka
  • 41 posts
Posted 25 May 2012 - 03:51 PM
Pistons are D shape
So if i understend you correctly head number; 12g295 is for 848ccm engines ?
#40 Naughty 40
Naughty 40
  • Just Joined
  • 270 posts
Posted 25 May 2012 - 03:55 PM
Yes that is correct
#41 jaydee
jaydee
  • 8,565 posts
Posted 25 May 2012 - 03:56 PM
295 is a cooper head, matched to D shaped 998 pistons, it could be either a cooper engine with a mismatched engine number (i dont get it as the shell is a cooper) or a replacement engine of some sort.
Are you able to get a rough measurement of the crank stroke?
850 bored out to accept D shaped pistons -> 2.88" (68.26mm)
998 cooper -> 3" (76.2mm)
#42 Spitz
Spitz
  • 1,716 posts
Posted 25 May 2012 - 03:59 PM
Pistons are D shape
295 can be used on 848cc ( like someone said..Inno used them on 848 )...and would have had to use raised top pistons
I don't think any other production 848cc cars used it though, just the 998 Cooper ( I think the Sport 850 did also,...but that wasn't a factory kit )
Edited by Spitz, 25 May 2012 - 04:00 PM.
#43 Cooperman
  • 23,565 posts
Posted 25 May 2012 - 04:51 PM
Now I'm confused. I've never seen any D-Top pistons for the bore of an 850. Were they special D-Tops?
I think there needs to be some accurate measurement of bore & sroke here to avoid all this guessing.
#44 jaydee
jaydee
  • 8,565 posts
Posted 25 May 2012 - 05:46 PM
I think hes got the 998 D tops we know, infact he measured about 64mm and D tops are 64.5mm
#45 ludiluka
ludiluka
  • 41 posts
Posted 27 May 2012 - 11:44 AM
Hi there
I find out that engine is 998ccm. Some guy who know almost everything about inno, mini told me that in italy they put engine number that was closest to hand :)
