So when im in traffic 1st and reverse gerar can be quite noisy, the noise isnt a rattle, more of a drone any idea?
1St And Reverse Are Quite Loud - Automatic!
minihasbroke
, May 20 2012 02:55 PM
4 replies to this topic
Posted 20 May 2012 - 02:55 PM
Posted 20 May 2012 - 03:22 PM
Is the oil level OK? Remember it's a different method to check an automatic. (see here: http://www.mra-minis...i-automatic.htm) Also make sure that your oil changes are up to date and that the correct grade has been used.
Posted 20 May 2012 - 04:51 PM
Is this when your selecting gears. Sitting with it in gear or driving in these gears ?So when im in traffic 1st and reverse gerar can be quite noisy, the noise isnt a rattle, more of a drone any idea?
Posted 20 May 2012 - 08:07 PM
No its when you're slowly moving..
Posted 20 May 2012 - 08:14 PM
See if it does it in 2nd ? Mine made funny noises like yours it turned out the exhaust & bracket would vibrate terribly under engine load at low speedsNo its when you're slowly moving..
