Clutch Verto Help
24 replies to this topic
#16 tiger99
tiger99
  • 8,584 posts
Posted 23 May 2012 - 04:21 PM
That could be the case, bits missing, but I thought that the problem was that the arm seemed to be jammed, although now it seems to be movable. Either way, it seems to be at the point where it has to come apart.
#17 tiger99
tiger99
  • 8,584 posts
Posted 23 May 2012 - 04:24 PM
By the way, no need to lift the engine again, just undo the mount, jack it up at the clutch end, and take the cover off in situ. It is an awkward job, one bolt in particular, but overall very much quicker, unless you like lifting engines needlessly.
#18 MiniMenzies
MiniMenzies
  • 190 posts
Posted 24 May 2012 - 12:05 PM
well I'm going to have to tackle it anyway quite vital, yeah i have a feeling that something has failed or I've forgot something. Do anyone know the exact order all the way from the centre bolt all the way back to the side of the engine like a line up?
yeah that was my idea :) don't fancy taking this engine out again.
#19 MiniMenzies
MiniMenzies
  • 190 posts
Posted 24 May 2012 - 06:21 PM
It's all off now what to do ;)
#20 MiniMenzies
MiniMenzies
  • 190 posts
Posted 24 May 2012 - 06:57 PM
There is masses of movement between the plunger and the release bearing when I too the front housing of the one that the bearing is on it was wobbly as anthything is that my answer well the actual bearing is fine I've looked over it is just where the plunger goes into the bearing it's not very tight. I can spin it about 15-20 degreese on the plunger.
#21 tiger99
tiger99
  • 8,584 posts
Posted 24 May 2012 - 09:31 PM
I think a picture might help.
#22 MiniMenzies
MiniMenzies
  • 190 posts
Posted 24 May 2012 - 10:34 PM
will do tomorrow :) my explanations are just great arnt they ;) I've been typing it on my phone haha
#23 MiniMenzies
MiniMenzies
  • 190 posts
Posted 25 May 2012 - 01:44 PM
I've got a video sorry its a bit crude
sorry it won't let me embed it http://www.flickr.co...N06/7267489256/
Edited by MiniMenzies, 25 May 2012 - 01:46 PM.
#24 tiger99
tiger99
  • 8,584 posts
Posted 25 May 2012 - 11:00 PM
I am not sure that the rotation matters. If you look here http://www.somerford...age=page&id=143 are all the parts (54, 55 and 56) present and correct? I think someone was suggesting that 54, the top hat, might be missing.
#25 MiniMenzies
MiniMenzies
  • 190 posts
Posted 26 May 2012 - 11:11 PM
I'm pretty sure I haven't its quite a vital part but there is a possibility i will have a look
