Cleaning My Heater ? ( How :s)
12 replies to this topic
#1 Mrt88
Mrt88
  • 300 posts
Posted 23 May 2012 - 03:03 PM
1. 1988
2. city
3.....
Hi guys n girls
as im gona have all my interior out this sunny weekend im planning on cleaning out my heater (not that i looks like we need them this week)
reading all the post has given me lots of ideas on what to use to clean it. but i cant figure out what to disconnect, how to clean and then how to bleed the system after ? :withstupid:
any ideas would be awesome ?
Ta
Edited by Mrt88, 23 May 2012 - 03:04 PM.
#2 leroy26
leroy26
  • 2,239 posts
  • Local Club: minisunleashed.com
Posted 23 May 2012 - 03:17 PM
to take the heater out
disconnect the two wires behind the panel
undo the two heater pipes
undo the large nut at the back
undo the two screws under the dash
undo the two hose clips on the the heater hoses
lift the heater up
and its out!
#3 Mrt88
Mrt88
  • 300 posts
Posted 23 May 2012 - 03:36 PM
Perfict, Ta buddy
Im printing that out and sticking it to my windscreen on saturday.
bit of a dumb question, what happens to all the liquid ? do i end up with a swimming pool in my footwell ?
im guessing i can drain it from the rad somewhere first?
#4 leroy26
leroy26
  • 2,239 posts
Posted 23 May 2012 - 04:21 PM
yeah take the bottom hose off m8
also remove your carpet cause you will get some in the car!
#5 sledgehammer
sledgehammer
  • 3,108 posts
Posted 23 May 2012 - 04:31 PM
I'm afraid it's a low point in the system - so remove the carpets - and get a bowel
I clamped my pipes with G clamps with cardboard around the pipes (do at your own risk - as I don't know how old your pipes are)
that stopped a lot of water - so I just worried about what was in the matrix
I didn't disconnect any other pipes - also do while the engine is cold
I gently washed the matrix in hot soapy water , as there was a lot of greasy fluff blocking the airways
and blow thru with an air line
for the water ways , I used washing up liquid with hot water , sealed the ports and shook it back and forth
if it's an aluminium core /pipes - then flush it well with clean water , as some caustic detergents corrode ally
#6 maccers
maccers
  • 1,875 posts
  • Local Club: LSMOC
Posted 23 May 2012 - 05:22 PM
Assuming you are taking the blower unit apart, and assumimg its the same type I have, ie metal case held together with tiny screws, I'd suggest to get a handful of new screws as some may be rusted away when you start to take them out. Also get a strip of foam for the matrix when you assemble it all, and seal the sides of the blower case with silicone or some sealant. Lets hope like you say we wont need heaters for a while though!
#7 Sleepy Stu
Sleepy Stu
    formerly Stewart_GT
  • 2,564 posts
Posted 23 May 2012 - 06:03 PM
You could refurb it at the same time if you wanted?
http://www.theminifo...age__hl__heater
#8 Mrt88
Mrt88
  • 300 posts
Posted 23 May 2012 - 09:12 PM
so if im reading you right buddy i can do it by claping the pipes in the cablin and not touch the engine bay ?
dont worry the carpits and everything will be out, hene why im going it now.
Thanks, looks awesome, printing that of too.
#9 sledgehammer
sledgehammer
  • 3,108 posts
Posted 23 May 2012 - 10:18 PM
you will need to top up the rad after
and the clamps did let some thru - but not a lot
If you have the plastic pipes on the matrix - be gentle when getting the pipes off
best of luck
#10 MINI WILL
MINI WILL
  • 559 posts
Posted 23 May 2012 - 10:24 PM
Keep the jubilee clips on the hoses on stick a socket extension bar in and clamp them back up if our quick you wont lose to much coolant just have a washing up bowl under just incase thats what i do.
#11 Mrt88
Mrt88
  • 300 posts
Posted 23 May 2012 - 10:30 PM
Thanks for the tips, glad I don't have to mess about disconnecting the engin rad as well.
#12 Mrt88
Mrt88
  • 300 posts
Posted 24 May 2012 - 07:31 AM
what works best to flush through the matrix ?
soda, soap, some sort of cleaner from halfords etc ?
#13 Mrt88
Mrt88
  • 300 posts
Posted 24 May 2012 - 12:20 PM
could you flush the whole car by sticking the hose in one of the inlet or outlet pipes once the heaters of ?
