Will The Standard 7.5 Brake Setup Be Good Enough.
17 replies to this topic
#1 clivemk1mini
clivemk1mini
  • 1,064 posts
Posted 25 May 2012 - 01:54 PM
As above I'm building a 1330 blow threw supercharged mini, I will be sticking with 10" wheels and was wondering if my standard 7.5 cooper s setup will be able to cope with the extra stopping power needed or should I change the callipers for 4 pots?
#2 SamMason
SamMason
  • 235 posts
Posted 25 May 2012 - 02:01 PM
Personally I'd get the best brakes you can.. Just to be safe..
I honestly don't know the difference between them (a lot of learning left to do here!) but from a safety point of view, get the best that you can..
#3 racingbob
racingbob
  • 3,061 posts
Posted 25 May 2012 - 02:33 PM
obviously the 4 pots be better
however see the car on my picture on the left here
it had cooper s set up 7.5 had 120 bhp at flywheel
#4 jaydee
jaydee
  • 8,565 posts
Posted 25 May 2012 - 02:37 PM
4 pots alloys are lighter, improving front suspension=better handing.
Get the best quality discs and carbon metallic pads, and the standard 7.5" setup will be really good.
#5 clivemk1mini
clivemk1mini
  • 1,064 posts
Posted 25 May 2012 - 03:31 PM
If I can rebuild my callipers and buy good discs and pads and they will be capible of stopping me I don't see the point in spending the extra on 4 pots. But if there not going to be up to the job then I would get 4 pots
#6 jaydee
jaydee
  • 8,565 posts
Posted 25 May 2012 - 03:37 PM
To be honest the biggest improvement the 4 pots will give is in handling terms.
Cooper S calipers will be capable of stopping the car for sure, plenty of historic race and rally cars that use them.
#7 Ethel
  • 26,011 posts
Posted 25 May 2012 - 04:42 PM
It's how fast you are going, rather than how much power you have, that matters. Though more power means you can get to a higher speed before you need to brake for the next corner. Two and four pot calipers have very similar total piston areas so develop almost the same pressure. 4 pots get a bit better leverage by being further from the axis
I don't think you'll notice much difference, do what you can to help keep them cool.
#8 Cooperman
  • 23,313 posts
Posted 25 May 2012 - 05:15 PM
Brake pads and brake fluid are the critical items. I have rallied many Cooper 'S's with sold 7.5" discs and 2-pot calipers without any fade issues. I now always use carbon-metallic pads and AP600 race brake fluid and the brakes are fine, even on long and twisty tarmac rally special stages when I can get the discs literally glowing red.
Just make sure the discs are top-quality and they and the calipers are in top condition.
#9 essexdaz
essexdaz
  • 42 posts
Posted 25 May 2012 - 05:48 PM
That is all us mini 7 drivers use, 7.5 s setup. Good fluid and carbon met pads.
#10 clivemk1mini
clivemk1mini
  • 1,064 posts
Posted 25 May 2012 - 06:07 PM
What discs should I get? Also do mini spares sell the carbon metallic pads
#11 Cooperman
  • 23,313 posts
Posted 25 May 2012 - 06:39 PM
Yes, I get my Carbon-metallic pads from Mini Spares. Simon@MiniSpares there and on here knows the ones you need.
#12 clivemk1mini
clivemk1mini
  • 1,064 posts
Posted 25 May 2012 - 06:53 PM
What disc should I go for?
#13 Cooperman
  • 23,313 posts
Posted 25 May 2012 - 06:56 PM
Mini Spares Part Number:
BRAKE PADS "S" CARBON MET...C-8G8993
#14 clivemk1mini
clivemk1mini
  • 1,064 posts
Posted 25 May 2012 - 07:44 PM
Ouch £75 for pads lol
#15 bmcecosse
bmcecosse
  • 9,699 posts
Posted 25 May 2012 - 07:58 PM
The 7.5 brakes will be plenty good enough - but I would try rather less expensive pads at first!
