Twin Hs2 Breather? Hmm.
Posted 26 May 2012 - 10:26 PM
These twin carbs have no breather connections at all so do I just not connect it anywhere? surely can't just leave an open pipe can i?
Cheers.
Posted 26 May 2012 - 10:29 PM
Posted 26 May 2012 - 10:34 PM
Posted 26 May 2012 - 10:45 PM
Posted 26 May 2012 - 10:52 PM
So one like this?
I will have to get one, I guess you just remove the pipe and attach it to the round tube that attaches to the block?
I read they are better than the pipe to the carb body?
Cheers for the replies.
Posted 26 May 2012 - 10:58 PM
I believe the engine breathers had to be linked back into the carbs originally to stop potentially harmful oil vapour from being released into the air. While this does the job it's not best for performance as you're essentially mixing oil vapour with the inlet of air a fuel into the engine. If you look at the engines on stuff like Miglias and Se7ens they run 3 or more breathers into an oil catch tank with a filter on it to help keep the pressure in the crankcase down.
Posted 26 May 2012 - 11:00 PM
Many thanks for the replies will get one as soon as I get these carbs on :)
Posted 26 May 2012 - 11:13 PM
Posted 27 May 2012 - 12:08 AM
Here's a picture of what it looks like fitted to the car, you can see the top of the PCV valve is the shiny round thing in between the carbs (ignore the bonnet hinge being used as a tent peg
Sven.
Posted 27 May 2012 - 12:47 AM
Posted 27 May 2012 - 07:54 AM
Posted 27 May 2012 - 08:10 AM
I may be wrong, so feel free to argue the point.
Personally i would free air the crankcase through a filter or feed it back to the airfilters somehow.
Posted 27 May 2012 - 08:23 AM
Posted 27 May 2012 - 08:36 AM
Posted 27 May 2012 - 08:44 AM
I wanted twins to go with my 12g295 head.
I don't want oil all over my engine!
Here is a picture of my twin carbs, I used to have the opening on the manifold but blocked both of them off.
I need to think about this.
