Twin Hs2 Breather? Hmm.
37 replies to this topic
#31 jpw1275
jpw1275
  • 2,803 posts
Posted 29 May 2012 - 08:18 PM
Yes, connect breathers via Y piece to the valve on the manifold.
Cheers for the help
James
#32 thebullet
thebullet
  • 1,337 posts
Posted 29 May 2012 - 09:32 PM
Mini and metro centre adviced me to run it open and down the side of the radiator to the floor, well I guess that is easy. They say they do it to all their cars with the same issue, says it runs better too.
******* ocks!
I've commented on this too many times on here. If you do do this set up don't EVER go onto a track.
Don't worry I don't plan too.... all the comments on here are useful but I just don't know which one to go for, I have spent too much money on these carbs and my car. I want to do something which is easy.
So maybe running it down the side with a filter on? I really am confused as to what to do for the best :/
Edited by thebullet, 29 May 2012 - 09:33 PM.
#33 thebullet
thebullet
  • 1,337 posts
Posted 30 May 2012 - 10:03 AM
You need this but looks like out of stock..
http://www.minispare...id=35134&title=
Buy two of these:
http://www.minispare...id=34394&title=
and fit them between manifold and heatshield
run a section of pipe from them to a Y piece like this:
http://www.minispare...id=33168&title=
and connect the breather to the Y piece, jo done.
Do not run the breather to filters, if you dont want them connected to the carbs (IE:the later twins has a connection to carb and not the manifolds, giving balance issues so some decide to not run breathers to the carbs) then run them to a catch tank..
The little pipes don't look big enough for the y piece connector?
#34 jaydee
jaydee
  • 8,565 posts
Posted 30 May 2012 - 10:09 AM
There should be a size of rubber hose that fits nicely over the spacer outlet and inside the Y piece, rubber grade has to be for unleaded fuel.
And keep an eye for blockage as the size will be smaller as the original breather pipe, as long as you have an healty engine you wont have any issues.
Edited by jaydee, 30 May 2012 - 10:09 AM.
#35 MiniElliott
MiniElliott
  • 378 posts
Posted 30 May 2012 - 10:10 AM
Buy two of these:
Im not sure but dont breather pipes have different sized ends. Im very interested in this topic as im curently looking at some twin carbs that dont have the breather. Hope you find a soloution.
Elliott
#36 thebullet
thebullet
  • 1,337 posts
Posted 30 May 2012 - 10:11 AM
My engine is healthy yes, I have so many options running round my head.
Running it down the side open,
Running it down the side with a filter on,
Getting those spacers and Y piece.
Drilling the manifold.
Confused is the word!
AGH
#37 cooperrodeo
cooperrodeo
  • 379 posts
Posted 30 May 2012 - 10:15 PM
Personally I would not vent the crankcase direct to atmosphere, with or without a filter. It's quite possible you will smell it inside the car. The way to do it properly with those old carbs is to fit a PCV valve to the manifold and make sure you have an oil filler cap which can breathe.
#38 thebullet
thebullet
  • 1,337 posts
Posted 30 May 2012 - 10:20 PM
Hmm ok another option, means I will need to get a breather oil cap and the valve. But another option. Thanks.
