hi ive got a 1979 mini with the lovely central speedo and was wondering what the various lights around it are meant to do. I know the blue one on the left is high beam and the red on the right ignition/ oil pressure. The other three do not seem to work one of the yellows seems to be blanked of and the green at the top (which i guess should be indicators) has had the bulb holder cut off at some point in its life. Any info would be much appreciated.
Central Speedo Warning Lights
robminibcy
, May 30 2012 12:19 AM
Best Answer Ethel , 30 May 2012 - 12:30 AM
flashy green - indicators
blue - h/b for high beam
red- ign for ignition
both orange are oil, but only the pressure warning one works since they deleted the "filter needs changing" some time in the 60's
Go to the full post
3 replies to this topic
Posted 30 May 2012 - 12:19 AM
Posted 30 May 2012 - 12:30 AM Best Answer
Posted 30 May 2012 - 12:33 AM
brill thanks will look at getting indicators fixed now
Posted 30 May 2012 - 12:39 AM
If it involves tinkering with that green light be aware it needs an insulated bulb holder.
might be of interest
