Stage 1 Kit Carb Needle
Posted 02 June 2012 - 08:34 PM
now my car is running lovely and I love it too bits and realllly don't want to mess it all up but............................... I want to go one step further and put a stage 1 kit on it. love the sound and increase performance a bit.
Putting the exhaust,exhaust manifold and inlet manifold on my self is easy but just a bit worried about the carb needle been reading some peoples posts on here about there stage 1 kit not running and its because the needle,
I dont have enough money to take it to the garage for them to do to,
so just wondering how hard it is to set the carb needle and spring up on the carb ???
i will take it to a rolling road on my birthday which is next month but just dont want it cutting out on me or wasting my petrol !!!
and i need the car for work so ... :) sorry for going on
Posted 02 June 2012 - 09:07 PM
Posted 02 June 2012 - 09:08 PM
Posted 02 June 2012 - 10:01 PM
Posted 02 June 2012 - 11:11 PM
You would probably want a AAU with a stage one as this is a bit richer, but not too rich which means it can be altered by rolling road people to suit.
Or you could use an AAA which is richer again and may also suit.
Changing the needle over in a HS4 is a very simple job, undo the 3 screws holding the dashpot on, lift it up with the piston, undo the screw on the piston and remove the needle, they the opposite to put it back together.
And a starting point for the mixture is screw up the jet until it is flush with the bridge (you will know what i mean with the dashpot and piston off) then turn the jet down two whole turns.
Posted 03 June 2012 - 07:12 AM
Posted 03 June 2012 - 07:13 AM
Posted 03 June 2012 - 07:38 AM
Needs very slight tweaking but for the time being its a pleasure to drive. Sounds fantastic too!
Posted 03 June 2012 - 07:43 AM
I'm 45 ..6 yrs no claims on the mini
With Stage 1 £225 fully comp....without I can get it for about £100
Posted 03 June 2012 - 07:47 AM
Posted 03 June 2012 - 08:09 AM
http://www.ebay.co.u...b#ht_500wt_1185
and a 3-2-1 manifold will it still work ????
Posted 03 June 2012 - 08:18 AM
Posted 03 June 2012 - 08:38 AM
Edited by jbs.998, 03 June 2012 - 08:38 AM.
Posted 03 June 2012 - 08:49 AM
Had it rolling roaded as well, best £70 I've ever spent
Posted 03 June 2012 - 09:07 AM
