Aaa Vs Aau - Stage One Kit
Posted 05 June 2012 - 06:58 PM
Things that have been replaced;
Inlet manifold
Exhaust manifold
Exhaust system
Cone air filter
Before anyone says it, I know it needs a new needle, tune, rolling road all that etc etc, but please read first
The car, after the changes, without the richer needle, was pretty much undriveable, wouldn't rev, no power, had to hold the choke out to get it to run a bit better, I then adjusted the carb slightly and got it a bit better, but obviously no-where near 'good'
I need the car for this weekend as I'm camping at the new forest before Beaulieu Show, so I'm going to go out and finally (thankyou bank holiday...) buy a needle so I can get it at least driveable, as it's obviously running very lean at the moment.
My main question is, will I be better off using an AAU needle, or the richer AAA needle? AAU usually comes in stage 1 kits but is there to be 're-profiled', would I be better going for the AAA needle as it's richer and then adjusting it slightly?
This will get set up properly when I can
Posted 05 June 2012 - 07:02 PM
Posted 05 June 2012 - 07:05 PM
I didn't know AAA was suited to 1098/1275s though, I take it that it won't be okay in a 998 then?
only questioning as I've never actually heard of the ABD needle being suggested over the 10+ stage one kit threads I've read, is it a common needle?
Edited by RossKnight, 05 June 2012 - 07:05 PM.
Posted 05 June 2012 - 07:08 PM
Posted 05 June 2012 - 07:09 PM
CUD1018 AAU needle for stage one kit with replacement element air
filter - non-modified casing
CUD1011 AAM needle for stage one kit with replacement element air
filter - modified casing (with holes drilled in)
AAM is very similar to AAA, I think the AAM is slightly richer
I'd say the AAA is best suited to a cone filter
Posted 05 June 2012 - 07:16 PM
Okay great, well I'll certainly look into that, thanksIt's not common to our stage 1 kits, as we supply the element rather than a cone filter. It is common as a richer stage 1 needle (at least with minispares anyway)
This is from a Keith Calver article on stage 1 tuning 998's
Again, thankyou for the advice, I think I may try and get hold of an AAA and an ABD as they're not expensive and that way I can try both
a minisport inlet manifold
unknown 2 inch LCB
and pancake KnN filter.
the car runs sweet as a nut and i didnt change the needle as i couldnt afford the kit from minispares. .
Posted 05 June 2012 - 07:18 PM
http://www.mintylamb.co.uk/suneedle/
basicly put in what needle is in then selected the more richer needles which are AAA,ABY,AAM and AAB
ABD doesnt seem to be that rich its basicly a stright line on the graph so let you decide where you want it to be richer
Posted 05 June 2012 - 07:23 PM
Also another quick question, it's idling very high, the idle screw on the carb doesn't seem to have much effect on slowing it down, could it be that the throttle cable is connected too 'short' so it's holding the carb open slightly more than it should, or shall just keep trying the idle screw?
Posted 05 June 2012 - 07:26 PM
Posted 05 June 2012 - 07:27 PM
Is it worth me getting a colour tune rather than testing by trial and error?
Posted 05 June 2012 - 07:29 PM
make sure your fast idle screw is not touching the cam area of the choke mechanism...
I did notice that it's either touching, or extremely close yesterday, which has just reminded me I was supposed to actually check properly haha
Posted 05 June 2012 - 08:26 PM
Posted 05 June 2012 - 08:32 PM
