Aaa Vs Aau - Stage One Kit
34 replies to this topic
#31 lrostoke
lrostoke
  • 6,923 posts
Posted 08 June 2012 - 10:22 AM
Its worth checking the mounting flanges on exhaust and inlet manifold..they can be different heights...Inlets normally the cause problem the casting where the nut sits can be thicker than the exhaust side.
Can either use a stepped washer or file back some of the casting to make them same height
#32 RossKnight
RossKnight
    One heck of a member
  • 2,539 posts
  • Local Club: JKSA MOC
Posted 10 June 2012 - 09:02 PM
This is a problem I had (may still have)
Bit of bodgery with a washer that I cut in half to sit on the lower side so it clamped it a bit better
After a weekend of driving, it's still no better, managed to get it set back to initial setting this week, but it's blowing somewhere, will look tomorrow
#33 samsfern
samsfern
  • 5,243 posts
Posted 10 June 2012 - 09:04 PM
And there was no gasket between the carb and the throttle linkage plate ross, which wouldnt help things.
#34 RossKnight
RossKnight
  • 2,539 posts
Posted 10 June 2012 - 09:11 PM
I thought we solved the missing gasket issue?
apparently not haha, I'll order one
#35 jbs.998
jbs.998
    Previously known as Rockabillypsychosis
  • 928 posts
Posted 10 June 2012 - 09:14 PM
Ah Ross, get your gaskets sorted mate!
