Spi Not Starting, Got No More Ideas!
Posted 09 June 2012 - 06:14 PM
I’m new to the forums and really need some help.
I have a rover mini cooper 1.3i 1994 spi.
The problem I’m having with my mini is that it won’t start! I have tried everything, I have tried all the following:
- New distributor cap
- New coil
- New HT leads
- New air filter
- New spark plugs
- Recently had a new alternator
- Recently had a new starter motor
My mini turns over but doesn’t seem to fire, there’s just no kick in getting it to start. I have connected some jump leads to it and another car and its starts straight away, I thought then it may be the battery but I have tested that and the reading is around 12. Once I disconnect it from the jump start its fine, I then turn it off and start it up normally and its fine again, however if I leave it for a few hours it doesn’t start again!!!!
It’s so frustrating!
Any help would be really appreciated.
Thank you
Posted 09 June 2012 - 06:26 PM
but i believe that there should be a ballast wire that goes from the solinoid to the coil, this is so that when the engine is cranked over the voltage at the coil doesnt drop and is took from the solioid.
sometimes the ballast wire can break down
im not completely sure with the ballast wire, just going by what i remember
Posted 09 June 2012 - 06:31 PM
Also, are you sure there isn't a drain on the battery? i.e something drawing a lot of current when its not being used. Another thing when are you measuring the voltage the jump or when it won't start?
Posted 09 June 2012 - 08:42 PM
If the earth strap (goes along the engine steady, between the brake servo and engine block) isn't in excellent condition then replace it. Best to fit a second one from the exhaust manifold to the bulkhead for peace of mind.
Check the battery earth as well.
Posted 10 June 2012 - 12:03 PM
Posted 10 June 2012 - 12:16 PM
Also put your meter on the battery neg terminal, then put the other lead onto a suitable earth on the body other than where the earth lead fastens, Get someone to crank it, if you see a voltage reading then you have "volt drop" on the earth. Remove clean and try again.
Posted 11 June 2012 - 01:15 PM
Thanks for all the replys from everyone, i will have a look tonight and see if i can see any problems with the earthing and with the wire from the solinoid. I will post up how i get on tomorrow. Thanks for all the replys though, if there is any more suggestions that would be great. Thanks
Hi All,
i had a look at the earthing and the wiring from the solinoid but couldnt see anything wrong! i put the battery on charge over night last night, so il try it when i get home, also ordered some new bettery terminals, one was a bit loose, could this have been causing it?
I will also try what orangeboy said tonight, Thanks alot everyone, keep the advice coming.
Posted 11 June 2012 - 01:39 PM
Posted 11 June 2012 - 08:42 PM
i started to think that it could be a fueling problem and put a few drops in the carb under the air filter and there you go it started. wierd! i thing looked at the purge valve and unplugged it and pluggd it back in again. then it wouldnt start again! what does the purge valve do?
i once again bump started it with another car and it started, turned it off, disconnected the jump leads and nothing, wouldnt even try to start.
put a new battery in that had been charging over night and it started straight away, i just think that if i leave it for a few hours and try it, it just wont start again.
could something be draining the battery really quickly?
thanks for everyones help.
Posted 11 June 2012 - 09:17 PM
Your battery could be giving 12v, but possibly not nearly enough amps to turn it, it could have a dead cell or two.
Take it down to your local ATS or battery place and get them to analyse it, they should do it free, and its amazing how bad it could be.
have had batterys before giving intermittent faults, and then take it to be tested and turns out to only be 27% efficient!
Posted 11 June 2012 - 10:27 PM
Posted 12 June 2012 - 07:11 AM
Posted 13 June 2012 - 07:18 AM
ok everyone, im even more stuck now! iv tryed everything mentioned above and no luck.
Hi all, as mentioned above, this is still the problem after trying everything, i have tryed the battery volt reading, its reading 12. when off and goes to about 10 or 11 when i try to start the car so i think the battery seems fine. could this be a fueling problem? where could the problem be? im hearing the noise of the fule pump so doubt it could be that. could it be the fuel filter?
any ideas?
Posted 14 June 2012 - 07:08 AM
Last night me and my dad took off the air filter and looked into the carb and put some fuel in, it started first time, we looked at the fuel evaporating when running and it starts to vaporise then stops???
any ideas?
need some help!
Thank you
Posted 14 June 2012 - 10:06 AM
Are you sure the fuel pump is delivering fuel ??
See http://www.theminifo...h/#entry2433572
