Hi I have a spare a plus engine In the garage but it only has the clutch housing what exactly do I need. I know I need fly wheel pressure palate clutch friction plate and it's a verto assembly what's the rough cost and what exactly do I need and where's best place to get it I also need the bell housing the bit where the leaver arm fits on too
Clutch Assembly And Flywheel
minimanjay
, Jun 10 2012 10:14 PM
2 replies to this topic
Posted 10 June 2012 - 10:14 PM
Posted 11 June 2012 - 08:24 AM
Moved to technical section
Posted 11 June 2012 - 10:52 AM
You say you have an engine - but do you have a gearbox ?? And are the drop gears present and correct? Any flywheel will fit - indeed I would strongly encourage fitting a pre-verto - and then you will need a cover (known as 'wok' on here for some reason) to match. I have the parts - but a bit far from you.....
