right trying to find something to tidy up my wires on my bulkhead .. thinking of putting loads of electric tape around it unless you can think of ote to tidy it up ???
Engine Bay Loose Wires ?
matthewrussell
, Jun 17 2012 07:13 PM
6 replies to this topic
Posted 17 June 2012 - 07:13 PM
Posted 17 June 2012 - 07:30 PM
What about wire tidies? They are plastic with a slit down the back and come in a range of colours..... Just a thought
Cheers james
Cheers james
Posted 18 June 2012 - 11:19 AM
insulation tape would be best or cable tidies. i use insulation tape, altho in needing to re-do it lol
Posted 18 June 2012 - 11:37 AM
I wouldnt use tape if i were you, as soon as it gets hot it will stick like crazy and if you ever want to take it off to repair the loom, or do the job properly with wire tidy things then you will find it unbelievably sticky underneath and the tape will fall off :)
Posted 19 June 2012 - 09:32 PM
Electrical tape is a PITA when you inevitably have to dismantle it.
You can buy something called loom tape designed for just this, it's like electrical tape but you can take it off fairly easily and it doesn't have a horrible residue.
Posted 23 June 2012 - 10:27 AM
as above 'loom tape' is your friend :) you can get some different types too, from the standard pvc type to a fabric type if you're going for a period look
Posted 23 June 2012 - 10:35 AM
Heatshrink mate all the way!!
Got my engine bay wiring pretty much done now and the bloke who did it with me loves the stuff and he's done wiring for years.
