Posted 23 June 2012 - 09:22 AM
I think that a hydraulic press will get them off. Your local garage or engineering company is likely to have one. You could try tool 18G 1243, if you can find one, but I don't think it will cope if it is very tight. But you could also put the shaft vertically loosely in a vice (provided the vice opening overhangs the edge of the bench, as it should), with the joint inner member resting on the vice jaws, and use a substantial punch and heavy hammer to drive the shaft out. Soak it in plusgas first.
The reason why it will not move may be corrosion, as stated above, or cold welding of the surfaces, or likely a combination of both. Splines like this must be well greased, because if not, you get any or all of wear, fretting, corrosion, or pressure welding if there is the slightest clearance, which there must be or they would never fit. You may have seen rough spots on similar things before, even bearings and gear teeth, that is galling, caused when a tiny pressure weld breaks again.
So, on reassembly, your new CV should be filled with an ounce of Duckhams Bentone Grease Q5795 or equivalent by the manufacturer, or by you every time you take it apart, but put a good lubricant grease (not copper grease, which is anti-sieze but has poor lubricating properties) on the splines, Bentone will do here too, but if not available, whatever is in your grease gun, such as Castrol LM, is much better than nothing.
It is good practice, every time the engine or driveshafts are removed, to not dismantle the pot joints but to use tool 18G 1243, because that way the splines are disengaged every time, and can be cleaned and greased. It also avoids disturbing the internals of the pot, and the diff oil seal. Likely as not, most Minis will have the engine out quite frequently nowadays, as the capability of DIY maintenance has improved over the years, and engine cranes are widely available (along with all the other stuff which is routine now, and scarcely available 30 years ago, like MIG welders), so there is ample opportunity to avoid this problem in future.
What we need now is an acceptably cheap source of tool 18G 1243 or similar. I am surprised that none of the spares suppliers have twigged that such a tool would actually be useful. There are pictures in the Haynes and Rover manuals, so you can see how it works.
