How To Polish A Carb?
17 replies to this topic
#1 adam davies
adam davies
  • 212 posts
Posted 23 June 2012 - 12:15 AM
I've exploring the internet quite a bit on this topic and I can't really find anything very helpful.
Basically I want to pollish my carb to a mirror effect without chroming it. I don't have any pollishing equipment but I guess it's possible with a bit of emery and some metal pollish?
Can anyone give me any instructions please? :shy: :proud:
#2 Ethel
  • 26,088 posts
Posted 23 June 2012 - 12:52 AM
You could just buy a cover, but if you do polish go carefully so you don't distort the dashpot.
#3 mike.
mike.
  • 6,176 posts
Posted 23 June 2012 - 08:46 AM
As above just buy a cover. You can buy shiny alloy cover for them, and then you can polish that more if you want to
#4 JustSteve
JustSteve
    Puke-Boy!!
  • 1,883 posts
Posted 23 June 2012 - 10:20 AM
No, don't just buy a cover!
The thing is its so hard to really polish the whole carb. So my ideal preference is to 'blast the main body, so it looks nice and new, and polish the dashpot, float chamber etc.
To polish, I use wet and dry (400, then 800, then 1200) then use loads of autosol! Will give you a near enough mirror finish :thumbsup:
#5 adam davies
adam davies
  • 212 posts
Posted 23 June 2012 - 11:44 AM
So basically sand it down to remove all the dirt and grime, then pollish like hell until it's shiny? :D
#6 JustSteve
JustSteve
    Puke-Boy!!
  • 1,883 posts
Posted 23 June 2012 - 12:36 PM
Remove all the grime with petroll first, its best if you take it off and you might as well rebuild it while you're at it
#7 Ethel
  • 26,088 posts
Posted 23 June 2012 - 12:53 PM
You really don't want to remove much metal. The dashpot is quite thin and may distort, through heat expansion, if it becomes irregular in thickness. Certainly don't use any power tools.
#8 JustSteve
JustSteve
    Puke-Boy!!
  • 1,883 posts
Posted 23 June 2012 - 01:04 PM
Yes, it's not 'that' thick and they can get quit pitted. You only want to be taking the top surface off to remove any scratches and light pitting.
#9 ANON
ANON
  • 2,682 posts
  • Local Club: pony
Posted 23 June 2012 - 06:49 PM
get it blasted then give it a quick polish
before and after pics
Edited by ANON, 23 June 2012 - 06:50 PM.
#10 surfblue63
surfblue63
    TMF fantasy F1 winner 2012
  • 2,539 posts
Posted 23 June 2012 - 07:44 PM
Get it ultrasonically cleaned, a lot better than blasting in my opinion.
http://carbcleaning.com/index.asp
Edited by surfblue63, 23 June 2012 - 07:44 PM.
#11 adam davies
adam davies
  • 212 posts
Posted 23 June 2012 - 09:16 PM
Where could I get it blasted or ultrasonically cleaned?
#12 dave-88_123
dave-88_123
  • 302 posts
  • Local Club: jurrasic coast minis
Posted 23 June 2012 - 09:22 PM
spray wd-40 on it and scrub with a small wire brush will clean it up well then wet and dry the dashpot use water as well then polish with autosole always worked for me
#13 ANON
ANON
  • 2,682 posts
  • Local Club: pony
Posted 23 June 2012 - 09:54 PM
send it to me ;-)
#14 surfblue63
surfblue63
  • 2,539 posts
Posted 24 June 2012 - 12:57 AM
Check the link in my original post.
#15 Carlos W
Carlos W
  • 10,114 posts
Posted 24 June 2012 - 06:16 AM
I've used maguirs metal polish before and got some amazing results
Edited by Carlos W, 24 June 2012 - 06:19 AM.
