Shortened Shocks
Posted 24 June 2012 - 09:14 PM
Just thought I would ask can shortened shocks be fitted to otherwise standard suspension setup or do you need the hi-Los also?
Nathan
Posted 24 June 2012 - 09:15 PM
Posted 24 June 2012 - 09:35 PM
Posted 24 June 2012 - 09:39 PM
Posted 24 June 2012 - 09:43 PM
But thanks though...
Posted 24 June 2012 - 11:18 PM
Posted 24 June 2012 - 11:23 PM
just have to be careful not to chop too much off the trumpet! (1:5 ratio at the rear and 1:3 at the front)
Posted 25 June 2012 - 12:35 AM
lowered shockers (dampers) can be fitted to an unlowered car, but you'll lose suspension travel on rebound, which could make cornering interesting.
http://www.calverst....per_lengths.htm - "lowered" is a subjective term it seems.
Posted 25 June 2012 - 12:29 PM
Posted 25 June 2012 - 01:15 PM
Posted 25 June 2012 - 01:51 PM
so there would be "spirited" cornering to be had if i was to fit shortened gaz shocks then to my otherwise standard suspension set up?!
If you want the best for a road mini, make sure your cones are in good condition, good dampers fully working.
I've got Hi-Los on mine, and it's at standard ride height (ish), but it allows me to get the height spot on if a cone wears differently to another or any other reason.
Then, adjustable lower arms to add a touch of negative camber, if you think you want to, rear camber brackets (bit more awkward especially if bolts shear).
Gaz seemed to be very popular when I was buying mine, and that's what I got, but I wouldn't buy Gaz again. For one, the rears are a very tight fit, due to the damper being larger diameter, and so the blue boot rubs on the inner arch, they were quite awkward to get on due to this aswell. Also, after about a thousand miles, they look like they're about 30 years old and are rusting. For the cost, I would have expected a better finish/coating on them.
Edited by Cerberus, 25 June 2012 - 01:52 PM.
Posted 25 June 2012 - 02:06 PM
Also cheers ethel this site would have me lost if it didn't exist!!
Cheers guys :)
Edited by scotty_1987, 25 June 2012 - 02:09 PM.
Posted 25 June 2012 - 02:26 PM
Posted 25 June 2012 - 06:03 PM
Fit wise, I had no trouble getting them in but also have nothing to compare them to but definitely wasn't a difficult task.
As you can see by the comparison site they aren't that short compared to your stock damper, it would be interesting to see some data logging on how much of the dampers travel is actually used in normal, if spirited driving.
From experience in performance motorcycles, the results generally show it's far less than expected.
I've personally never had any binding or skipping as a result of using them.
Posted 25 June 2012 - 06:31 PM
As above, it's easy to trash your trumpets as the suspension doesn't settle to its final height right away and it's hard enough cutting them accurately & square. I'd say Hi-lo's are worth their money.
yeah I cut mine shorter than i wanted as i didnt have the bottle to cut the amount off as planned, and sanded it off squarely, in the end i cut about 2.5mm off which is half what i wanted but I am happy with the height as I didnt want to fit lowered shocks and what not
