Precisely, lots of cars HAD gutters. How many NEW designs have them now? How long has Defender been around in one form or another? It was type tested ages ago, if it's passed a type test then it doesn't have to be re-tested during production. No Defenders, Freelanders or anything come with a snorkel as standard, they are aftermarket fitment so don't get tested. Same with lamp gaurds. The SVA means that a car has to be roughly the same standard as a production car, production models are type tested to a certain standard and then lots of parts that wouldn't pass are fitted after manufacture which is why we have dealer fit options. Jammy is right, the number plate lamp sticks out too far and has sharp edges. Wing mirrors are collapsible and rounded all over (if they have an approval mark which they would have to have to pass the SVA). The rules are something like that nothing on the outside can have a 90 degree corner on it anywhere that can come into contact with a 100mm ball. Any corners have to have a radius of at least 6mm (or 8 maybe). I know that you couldn't realistically get injured by these things but then I didn't write the rules now did I? There's no point in taking issue with the rules here mate, the rules are the rules. If you don't like them talk to your MP about them.
Yes a Minus probably could pass the test, but I think you might need engineering documents that refer to the body shell manufacture or something like that. One of the good things about the SVA though is that you don't always get a Q plate on a kit car. I think that if you can proove all the parts are new or fully re-conditioned rather than second hand then you get a new (as in this year) number plate. If you can prove that all the major second hand parts and the shell are the same age then you can get an age related plate (as in the age of the car). I think you only get Q plates on cars of undeterminable identity or age now. Also it means that your car is as good as any other new car, including no MOTs for three years!
Edited by Dan, 15 March 2006 - 08:57 PM.
