Having Oil Problems With A New Engine, Piston Clearance Ok?
32 replies to this topic
#31 Jellevandok
Jellevandok
  • 100 posts
Posted 10 July 2012 - 09:44 AM
Also if the heads had porting work done to it, it's worth checking they've not gone too close to the pushrod holes with the inlet ports, this can then suck oil into the engine.....
Another good look at the inlet port showed that there was a very small hole indeed. The maker went through the wall so on cylinders 1 and 2 he must have gotten oil in the mixture when the oil was getting warm.
#32 Jellevandok
Jellevandok
  • 100 posts
Posted 16 July 2012 - 10:48 PM
New piston rings that fit, check. A better hone finish, check. Cylinderhead fixed, check. Starting up tomorrow and hopefully a nice track day Saturday...
#33 Jellevandok
Jellevandok
  • 100 posts
Posted 25 July 2012 - 12:26 PM
Edited by Jellevandok, 26 July 2012 - 09:40 AM.
