having scoured the FAQ section i would like some advice on whether A+ and A rod change gears are interchangeable?
if not, which are the parts inhibiting this...
thanks
interchangeable gears
magal2005
, Mar 13 2006 04:06 PM
3 replies to this topic
Posted 13 March 2006 - 04:06 PM
Posted 13 March 2006 - 06:02 PM
Basically, no, the cut of the gears if different, so you can't mix the gearsets.
but what you can do is have a A+ or A set of drop gears with an A or A+ set of gears and an A or A+ crownwheel and pinion..
Posted 13 March 2006 - 06:50 PM
o no i have gone cross-eyed!!
Posted 13 March 2006 - 06:59 PM
nice, thanks,
so to fit a set of PRE A PLUS Rod change straight cut gears into my 1293 A PLUS Rod change lump i will not need to source a new gearbox cover etc...
