- Poor brake effecencey: the mot tested said that he could get his foot all the way to the floor and it didn’t stop the rollers.
- engine emissions where too high (not sure what he was measuring them in but he said that the reading was 1800 and the limit is 1200)
Basically with the brakes when you put your foot on the pedal, you have to push really hard but you can get it to reach the floor. the local mechanic said that its probably the master cylinder but if you pump the brake pedal it doesn’t build up pressure in the brake lines almost like there’s still air in the system, but I have bled the brakes countless times now using both an easy bleed kit and someone sat in the car pumping the pedal and I cant get any more bubbles out. If it was the master cylinder I though that I should be able to pump up pressure, but it wouldn’t hold the pressure and slowly leak pressure allowing the pedal to slowly reach the floor?
with the engine emissions the mini had a hif44 carb fitted when it went for the mot but it was leaking the dash pot oil into the carb (which I think was part of the reason why the emissions where so high) and it would only run for about a 1.5 miles before the car would just stop when its used all the oil in the dash pot. so I swapped the carb for a spare hif38 that has had a full rebuild with new seals and was ultrasonically cleaned, the emissions are now fine (reads 2.5 on the gunson emissions tested) and the dash pot doesn’t seem to loose oil but it now runs fine for a while you can drive the car up and down the road but it suddenly stops and back fires through the carb? Not sure where to start in fixing this as the engine has electronic ignition and it sounds like its running fine then just suddenly back fires?
As I have said I have now got to the point that I have run out of ideas as to how to fix these problems, sorry for the long post but I hope I have given you enough information to give an idea as to what might be wrong. Any suggestions would be grateful
Thanks Sean
