Does Anyone Do Metal Laser Cutting?
23 replies to this topic
#1 conlad
conlad
    Previously known as ct16mini.
  • 2,054 posts
  • Local Club: Hilltop Minis
Posted 11 July 2012 - 04:15 PM
Quick question and hopefully someones knows or does it themselves!
Only asking as I need some holes cutting for a custom switch panel I want to make :)
Cheers all!
#2 stretch tech
stretch tech
  • 1,363 posts
  • Local Club: A5 & Mini Mainiacs
Posted 11 July 2012 - 04:25 PM
what type of metal is it ? you could use a drill and hack saw if it is thin-ish metal :proud:
#3 conlad
conlad
  • 2,054 posts
Posted 11 July 2012 - 04:54 PM
Its sheet steel about 1.5mm thick but its such a small area to cut the switch holes with a hack saw :(
#4 stretch tech
stretch tech
  • 1,363 posts
Posted 11 July 2012 - 04:58 PM
do you mean to put in the original switch panel hole ? are you going to be using standard switches ? if so you could drill many holes around the edge to make them fit and the surrounds will cover the uneven edges...it'll be cheaper than laser cutting
i do have access to a laser cutter at sixth form...might be able to make one for you :genius:
#5 conlad
conlad
  • 2,054 posts
Posted 11 July 2012 - 05:44 PM
Yeah man you got it ;)
A metal one?? I might try the drill idea later this week.and file the edges :)
#6 stretch tech
stretch tech
  • 1,363 posts
Posted 11 July 2012 - 08:27 PM
pretty sure it is, it'll cut up to 10mm think from what i can remember but the thinner the material the quicker and easier it cuts :proud: i think you'd be best to drill/file it your self though...much easier and you'll get it done in less than an hour no problem :proud:
#7 conlad
conlad
  • 2,054 posts
Posted 11 July 2012 - 08:28 PM
nice one, cheers for the insight rhys :)
will put it up on the ICE thread i have :D
#8 stretch tech
stretch tech
  • 1,363 posts
Posted 11 July 2012 - 08:32 PM
no worries...will check it ;D i'll have an update for my ICE one at the weekend when i cut a new board and wrap it with my new carpet and i'm fitting the rest of my interior too so more updates for my main build thread :proud:
#9 conlad
conlad
  • 2,054 posts
Posted 11 July 2012 - 08:35 PM
good lad!
are you moving them speakers up front?? ;)
#10 sledgehammer
sledgehammer
  • 3,108 posts
Posted 11 July 2012 - 08:44 PM
Firstly ignore the sh!t welds - it was done quickly , you will only need tacks anyway
instead of trying to create holes - make a box with angle & plate
the vertical gap is 30mm approx - so 30mm plate the width you want
horizontal is the width of the switches you want butted together
I left the join lines in - I like them
may put a start switch in the middle , choke & heater outside
Edited by sledgehammer, 11 July 2012 - 08:51 PM.
#11 stretch tech
stretch tech
  • 1,363 posts
Posted 11 July 2012 - 08:45 PM
unfortunately no i'm not, i really like the late 80's retro-cool look of the original dash and i don't want my great big ugly speakers ruining it >_< i set out to keep my thirty as standard looking as possible and i'd rather loose a little bit of sound quality to keep the factory fresh look of the interior :lol:
sorry i'm a little ocd when it comes to the looks of things :teehee:
#12 conlad
conlad
  • 2,054 posts
You genius!!!
Never thought of doing it like that!
#13 conlad
conlad
  • 2,054 posts
Posted 11 July 2012 - 08:46 PM
cant say i blame you!
i've got a bodykit, evil eye headlight covers and alfa romeo seats!! far from standard :D
#14 stretch tech
stretch tech
  • 1,363 posts
Posted 11 July 2012 - 09:13 PM
plus my mates think it looks epic with four great speakers completely filling the cavity under the rear seats :lol:
i like the look of you body kit...i wanted one of the german export thirties as they came standard with a body kit :gimme:
#15 conlad
conlad
  • 2,054 posts
Posted 11 July 2012 - 09:23 PM
True haha :D will look good
No way?? Got a pic of one? :)
