Hi there I'm doing a full rebuild of my mini at the stage of putting driveshafts and hubs back on, but looking at my driveshafts I noticed one was missing the ball bearings and the kind of outer cage if that makes sense, now I've found the ball bearings but can't find the outer cage part, can you buy these separately or can u buy a new joint but I'm not really sure what I'm looking for, incase I'm not very clear it's the end that slots into the diff, oh and it's a 1988 city 998cc thanks
Driveshafts
corrado vr6
, Jul 13 2012 05:02 PM
5 replies to this topic
Posted 13 July 2012 - 05:02 PM
Posted 13 July 2012 - 05:29 PM
If I understand you correctly, you left the joint together, but without the ball that got lost? If so, there is no other 'outer cage'.
There's a centre part, then the 'cage' that the balls sit it, and then that slides into the 'pot' which slides over the Diff output shafts :)
Posted 13 July 2012 - 05:34 PM
Yer I got the inner bit that the balls would sit in but haven't got the bit that hold them there as in the outer cage
Posted 13 July 2012 - 05:37 PM
Ahh I see. You shouldn't really disassemble them anyway, so even if you did have it, you *should* replace.
Posted 13 July 2012 - 06:04 PM
Ok thanks mate to be honest it just fell apart from memory when removed!
What is the name of the item / items I need?
Thanks again
Thanks again
Posted 13 July 2012 - 06:07 PM
Pot joint
