1987 Austin Park Lane Value?
13 replies to this topic
#1 HastingsMini
HastingsMini
    Just On Tickover
  • 6 posts
Posted 15 July 2012 - 02:47 PM
Hi!
My mini has been off road for about 5 years and is in bad shape. Since it failed it's mot back then and I subsquently getting ill, it's not been loved at all. It's now come to the time where it has to go but I have no idea of it's value. Can you help me?
I will try and list as many details as possible but if I miss something then let me know and I'll add it.
AUSTIN MINI PARK LANE 1987
Bought as my first car:
My nan paid £2000 for it and the previous owner had done it up some what with bodywork and a paint job.
I liked Mini's but I knew nothing about cars and had sadly didn't look after it very well.
Current Photo:
Attached File  miniphoto.jpg   91.01K   15 downloads
Important:
Back when the car was active, about a year before it came off the road, My gaskets blew and basically eneded up with some lowlife mechanics who took out the orginal engine and put the current engine in. I knew nothing about cars so I think I was fobbed off with an engine from a scrap mini? I have no idea about what CC it is. The Mileage is 212543
The last MOT was in 2007 and it's reasons for failure was the following:
-Nearside steering rack gaiter split
- Nearside inner seatbelt anchorage is excessively corroded
- Same for offside seatbelt anchorage
- Nearside outer vehicle structure has excessive corrosion
- Same for offside
- Same for rear
nearside front tyre tread deph below requirements
- same for offside front tyre
- same for offside tyre
- nearside front subframe attatchment rubber mounting deteriorated resulting in excessive movement
- Same for offside front subframe attatchment
Photos:
Attached File  263215_10150264730822808_2599632_n.jpg   91.78K   6 downloads
Attached File  318860_10151013811082808_1853370175_n.jpg   76.96K   12 downloads
Attached File  315391_10151013812962808_255404276_n.jpg   76.29K   6 downloads
Attached File  389074_10151013815872808_421896515_n.jpg   58.85K   5 downloads
Attached File  399409_10151013816377808_1715748056_n.jpg   66.15K   11 downloads
Attached File  552504_10151013818127808_1708630946_n.jpg   63.82K   6 downloads
Attached File  599371_10151013816747808_59748834_n.jpg   73.52K   6 downloads
Attached File  487193_10151013820287808_638925691_n.jpg   62.55K   14 downloads
Attached File  314708_10151013819887808_1329043837_n.jpg   50.69K   8 downloads
Attached File  563479_10151013820972808_1393428962_n.jpg   49.57K   10 downloads
So the subframe is the main issue. The car turns but I believe the battery is dead. Electronics seem fine.
Again I'm rubbish with cars so if theres some more info that will help value it then please let me know and I will try and find the details.
- Dave
#2 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 15 July 2012 - 02:50 PM
300
its a project needing resto inc sills doorstep rear subframe etc etc
300 if complete.
#3 jb93
jb93
  • 2,439 posts
Posted 15 July 2012 - 02:51 PM
£500
Edited by jb93, 15 July 2012 - 02:52 PM.
#4 mini-luke
mini-luke
    Postman Pat
  • 2,362 posts
Posted 15 July 2012 - 02:55 PM
No more than £500. What's the engine number? It's just behind the alternator on the top of the block.
#5 HastingsMini
HastingsMini
    Just On Tickover
  • 6 posts
Posted 15 July 2012 - 03:06 PM
Will go get that now Luke.
#6 HastingsMini
HastingsMini
    Just On Tickover
  • 6 posts
Posted 15 July 2012 - 03:13 PM
MINI SPORT
WFM1026/4NW
#7 mini-luke
mini-luke
    Postman Pat
  • 2,362 posts
Posted 15 July 2012 - 03:18 PM
It's an A+ 998, correct for the car even if it's not origional. Could you take a piccy of the Mini Sport bit? Sounds like it may have been a recon from them.
#8 pothole
pothole
  • 317 posts
Posted 15 July 2012 - 04:27 PM
Put it on EBay you will be surprised what people will pay
#9 HastingsMini
HastingsMini
    Just On Tickover
  • 6 posts
Posted 15 July 2012 - 04:56 PM
Attached File  563474_10151016124232808_1917675518_n.jpg   51.39K   9 downloads
Attached File  428879_10151016123852808_215189388_n.jpg   48.71K   12 downloads
#10 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 15 July 2012 - 05:00 PM
those arent the engine number.
under the spark plug cloest the radiator (so stood infront of car, the 4th spark plug from your left) is a ledge with a plate with numbers. thats the engine no. just above the alternator.
#11 HastingsMini
HastingsMini
    Just On Tickover
  • 6 posts
Posted 15 July 2012 - 05:12 PM
My bad. Here's the engine number:
Attached File  553167_10151016163902808_2112485533_n.jpg   58.37K   13 downloads
99HE20 14127
#12 mini-luke
mini-luke
    Postman Pat
  • 2,362 posts
Posted 15 July 2012 - 05:25 PM
Source Vehicle : Mini Engine type & CC : A+ 998 cc Transverse mounted Fueling : HS4 FZX1415 with Tamperproof Capstat, AAC Needle, Red Spring Engine features : Servo Assisted Brakes1st Alternative compression ratio95 Ron Unleaded petrolPre-engaged starterADO 20 Design variants Gearbox features : Std. Ratio Rod Change gearbox with Pot Joints 3.105:1 Final Drive
#13 HastingsMini
HastingsMini
    Just On Tickover
  • 6 posts
Posted 15 July 2012 - 06:00 PM
Thanks for the info :)
So I should ask for £500?
Not a big fan of Ebay and it's fees.
One other thing I forgot to add was I have all the keys except the door key which snapped in half in the passenger side.
#14 mini-luke
mini-luke
    Postman Pat
  • 2,362 posts
Posted 15 July 2012 - 06:02 PM
That's not much of an issue , mini door locks are very cheap and easily replaced. I'd give it a shot at £500, yes.
