What amp
Posted 15 March 2006 - 11:21 AM
Aiwa CDC-R 227
6.5" Mutant coaxials (90w RMS, 180w Max)
12" Mutant-X sub (450w RMS, 900W Max)
The headunit may be upgraded soon depending on my budget but its not a bad unit.
So my question is what amplifier should I get to power this system - should I get a good mono block to run the sub and run the coaxs off the HU or should I get a 3 / 4 channel amp to power the lot?
Posted 15 March 2006 - 11:47 AM
Most budget 4ch amps only really put out 250w RMS or so when bridged...then again, what voice coils does the sub have?
If it's a single 4 ohm, then a cheapish mono amp won't really help as they tend to do the most power and lower impedences!
Posted 15 March 2006 - 03:53 PM
Those are the RMS figures quoted in the docs that come with the speakers. Obviously I havent been able to try them yet...
And yes the sub is a 4ohm coil type
Mutant recommend a bridged 300W amp... obviously one of their own but this may provide some clues as to alternatives?
Posted 15 March 2006 - 04:30 PM
What's your budget for the amp(s)? Do they have to be knew, or will 2nd hand be ok? That will have a pretty big bearing on what you can get!
Posted 16 March 2006 - 09:45 AM
Ehm I'd say my budget would be up to about a £100 maybe more but that'd be stretching it. And I have no problem with second hand amps...
Posted 28 March 2006 - 10:39 AM
Posted 28 March 2006 - 11:44 AM
Personally I'd get the JBL 75.4 (yes, I know it gets recommended a hell of a lot) It's within budget, powers the fronts nicely...but does only give the sub 250w RMS
I can't think of any other options for such little cash that fulfil enough of your criteria!
Posted 28 March 2006 - 01:35 PM
If I were to get a monoblock to power the sub what sort of power should the amp give the sub, and how will the fronts sound being run off the HU (for the time being)?
Sorry I forgot to put in a link to the amp that I meant
Will running the sub at 250w RMS when its rated at 450w RMS do it any harm?
Posted 28 March 2006 - 02:28 PM
Depends what you want...if you're a basshead, then get an amp that does 500w RMS @ 4ohm for the sub and run the fronts from the HU
If you want a better overall sound, then get a 4ch amp like the JBL I suggested
Posted 28 March 2006 - 06:59 PM
It's not that hard to edit your post so it doesn't sound like you're repeating yourself
just been reading this post and im after an amp to i got two JVC speakers and the watts are 280 what amp will i need get the best out of them i dont understand amps
Posted 28 March 2006 - 07:15 PM
Is the wattage an 280watts rms or is it max, the rms figure is the only reliable figure you can use, max figures just tend to be made up and mean nothing.
Posted 29 March 2006 - 10:38 AM
the max watt for my speakers are 280Watts! so huummm im guessing i will need an amp of higher watt like anthing from 300watts ?
Posted 29 March 2006 - 11:41 AM
Posted 29 March 2006 - 02:13 PM
No, you need to find out the RMS value of the speakers...none of this MAX poo
power range: 2-55 watts RMS (280 watts peak power)
Dos that help ?
Posted 29 March 2006 - 03:56 PM
I'd like at something with 50w RMS or so...should be dead easy
http://www.caraudiod...?products_id=37
http://www.caraudiod...roducts_id=3581
Et voila
