My car has been sitting for well over a year. When I went to depress the clutch pedal it was stuck solid. thinking this would just be the clutch arm sticking, I pressed harder. By doing this I have ruined the seals in the slave cylinder (which was ropey at best anyway). However more worrying is the arm is stuck in the "clutch depressed" position and hasn't returned to its usual position! Is it likely that the arm is just a little stiff and needs to be freed up or am I looking at something worse? Obviously I will be replacing the slave cylinder and will use a braided hose.
Sticky clutch arms?
barryc
, Mar 15 2006 01:50 PM
4 replies to this topic
Posted 15 March 2006 - 01:50 PM
Posted 15 March 2006 - 01:56 PM
work the arm in and out with a crowbar and lots of penetrating oil and it'll be fine. it'll be the plunger thats seized where it goes into the wok...
Posted 17 March 2006 - 02:21 PM
Forgot to ask, what type of clutch do I have. The release arm is the long type and the slave cylinder is mounted on the bellhouse casing rather than a seperate bracket.
Posted 17 March 2006 - 02:26 PM
i had the exact same problem on my old 93 cooper, just soaked it in WD and worked it with a big bar
Posted 17 March 2006 - 04:02 PM
you have a pre-verto clutch, and yeah as Bud says, penetrating oil and work it backwarda and forwards should do the trick, you've encountered electrolytic corrosion there! (and the perils of mixing aluminium and steel in close proximity + water = bad!)
