Your talking about HID xenon kits
yip you can get them for the H4 lamp but pricey..
355 quid
Clickythe details..
H4 H.I.D. Interpower X5 Conversion Kit
The Ultimate Lighting Upgrade Brightest Light, Longest Life, Highest Quality!
We are offering what we believe to be the ultimate H.I.D. headlamp conversion kit. We have tested this kit against many HID kits including the leading branded systems. It offers a massive 300% improved vision over a standard halogen bulb.
Our H4 kits are HI/LOW kits that convert BOTH the main and dipped beam to HID. Unlike others they do not use a precariously mounted halogen bulb for the main beam, they use a high quality solenoid to shift the HID bulb from main and dipped beam position. This means you do not lose any functionality of your headlights.
The kit consists of 2 bulbs, 2 ballasts, 2 wiring harnesses and everything needed to fit the kit including full fitting instructions. The bulbs are converted D2S bulbs designed to directly replace your existing halogen bulb. They fit straight into your existing headlight unit.
We feel it is the best, quickest, simplest and most cost effective solution to convert your car to an H.I.D. Xenon headlamp system.
This system (unlike all others we have tested) does not require relays or seperate wiring harnesses to the battery. They are also designed to only connect one way which makes them entirely fool proof. The wires are also colour coded which makes installing this kit very straight forward.
Through testing we have found these HID kits take on average, 30 mins to an hour to install, and can be installed as a DIY fit. However, if you have any doubts we recommend using an auto electrician.
The 8000K kit has a distict blue tint for the ultimate styling upgrade for your vehicle.
