cat stole my bushes
Posted 15 March 2006 - 06:57 PM
i undid the top engine steady to try and rock the egnine back over, but no amount of movement will line it up. im sure that when it first happened it would line up. does anyone know why the engine has moved and how i can fix this? i need to do it soon as i dont want my manifold broken again.
cheers,
stefan
Posted 15 March 2006 - 07:01 PM
you need to push harder! it will go in, you are pushing on a very heavy engine! (and things like the exhaust are trying to hold it in place) Put your shoulder in it! (or get the cat to help!)
Posted 15 March 2006 - 07:03 PM
well, me and my dad arent exactly small guys and we couldnt push it. it really wont budge at the bottom.
hmmm now i duno what to do!
Posted 15 March 2006 - 07:14 PM
Posted 15 March 2006 - 07:18 PM
Posted 15 March 2006 - 07:23 PM
Posted 15 March 2006 - 07:25 PM
Posted 15 March 2006 - 07:27 PM
the first time i did this it took about an hour because i didnt realise it was slightly low, then next time 2 mins from jacking it up, might be the same problem so well worth a look.
Posted 15 March 2006 - 07:39 PM
what about if i bought one of those ultimate steadies for the gearbox and put that on?
Posted 15 March 2006 - 07:45 PM
fitting a gearbox steady would help to stop the engine rocking.
as too would a top ultimate engine steady.
Posted 15 March 2006 - 07:50 PM
right. if i have no steadies attached to my engine, should it be moving back and forth like an inch? if not, im guessing the engine mounts are shot. yay. how much will this cost me? and im assuming i have to take it to a garage for them to overcharge me to fit them =)
this would also explain why its moved since the crash?
Posted 15 March 2006 - 08:09 PM
Posted 15 March 2006 - 08:11 PM
You are?? I thought we agreed our relationship was just going to be for fun?? *I'm with Jammy.
Posted 15 March 2006 - 08:14 PM
Posted 15 March 2006 - 08:18 PM
your best bet is to do it yourself or get someone you know to do it for you.
its not a hard job but can take a while, if you by the ones with captive screws like this;
http://www.minispeed...ct&id=21a1902st
you dont have to fiddle around trying to get a spanner into the engine bay when it comes to tightening them up, just line the engine up and put the bolt through the subframe and into the mount.
the best way of finding out hiow to do this is to get a haynes manual.
if all else fails get a garage to do it, but i dont know how much they would charge to be honest, its a couple of hours job basically.
and no it should be moving an inch, that sounds like the mounts have perished to me.
I'm with Jammy. Take the weight off of it a bit by jacking SLIGHTLY the bottom of the engine. Make sure you put a block of wood in there though. Don't want the cat gettting all oily from a cracked sump!
i believe that was my comment pikey7, no offence taken
