hi all...a new member.......
a few days ago i brought a little mini runaround for the missus.....
got it at a good price so the moneys not the issue...
problem is that when under breaking there is a juddering like something is loose.....
any ideas are very welcome....[mini mayfair 1ltr auto}..
cheers....
the fox
juddering
the fox
, Mar 15 2006 08:00 PM
7 replies to this topic
Posted 15 March 2006 - 08:00 PM
Posted 15 March 2006 - 08:35 PM
grab the top of your engine and try to rock it. Chances are there's an engine steady bush gone.
Posted 15 March 2006 - 10:13 PM
it could be that your discs are warped i had a similar problem when i braked the braking didnt feel consist like a sort of udder
Posted 15 March 2006 - 10:52 PM
whos to say they have discs. sorry do u have drums all round because mine do that i hope its nothing major its always done it i just thaught it was just the charats of drums?!?!
Posted 16 March 2006 - 07:18 PM
thanks for your ideas guys an gals?.....whos to say they have discs. sorry do u have drums all round because mine do that i hope its nothing major its always done it i just thaught it was just the charats of drums?!?!
will have a look at the engine rubbers?...think discs on them? the juddering /knock seems to be only on drivers side and is when breaking down{gets pretty severe}...
will keep you posted when i manage to get a look....{weather permitting}...
cheers...the fox
Posted 16 March 2006 - 08:11 PM
is there a vibration through the pedals? the steering rack?
Posted 18 March 2006 - 05:09 AM
G'day guy's, the shudder your experiencing could be related to several areas. Firstly the disc's or drums could need machining as they maybe warped or out of round . Secondly check the tie rod ends on the steering rack as a badly worn tie rod end can give a vibration under braking . In my experience if the engine stabilizer bush's are worn you tend to get more of a thump going on and off the throttle . Hope this has been of some help to you and please let us know what you find. Regards Ianis there a vibration through the pedals? the steering rack?
Posted 18 March 2006 - 01:17 PM
Check the bushes on the tie rods or the actual tie rods themselves. The standard ones are very skinny, and sometimes people try and use them as a jacking point They bend rather easily.
