O/s Headlamp Going Crazy
4 replies to this topic
#1 lewBlew
lewBlew
    Previously known as theboybradley.
  • 1,238 posts
Posted 24 July 2012 - 10:18 PM
Sorry to add to the millions of headlight posts but I have searched and can't find one quite like mine.
Basically all of a sudden my o/s headlight has started misbehaving, like this:
Sidelights on, ignition set to 0 - both sides shine a bit as expected, nice and even
Sidelights on, ignition set to 1 - n/s goes slightly brighter and o/s a bit dimmer
Headlights on - n/s ok, o/s trying a bit harder but still way too dim
Full beam - n/s ok, o/s goes almost goes out but shines a bit!
Any ideas what's up? Everything else electrical on the car seems to be working, however also today the front n/s indicator bulb went, and it's definitely the bulb in that case as I swapped them to check. I also accidentally took apart the dim/dip relay while I was trying to diagnose the broken bulb, but it still clicks and does it's job with the n/s headlight, just not the o/s one it seems!!!!
EDIT: I'm assuming these units are sealed and it can't be a bulb if it's still emitting some light?
Edited by lewBlew, 24 July 2012 - 10:24 PM.
#2 lewBlew
lewBlew
  • 1,238 posts
Posted 24 July 2012 - 10:41 PM
EVERYBODY STAND DOWN - I'VE FIXED IT!....
....twiddled the wires going between the two headlights.
I'll leave this quick fix here to help prevent others looking stupid also.
Now I wonder what I've broken by fixing that...
Edited by lewBlew, 24 July 2012 - 10:42 PM.
#3 sledgehammer
sledgehammer
  • 3,060 posts
Posted 25 July 2012 - 09:45 AM
clean up the contact areas in the bullet connector
and a nice blob of vasilene to stop any corrosion
I would also check the earth is good
Edited by sledgehammer, 25 July 2012 - 09:46 AM.
#4 mike.
mike.
  • 6,176 posts
Posted 25 July 2012 - 09:59 AM
As above, most likely a loose connection somewhere. The bunch of bullet connectors are the grill are often neglected and takesome weather abuse from the front of the car.
#5 tiger99
tiger99
  • 8,584 posts
Posted 25 July 2012 - 04:44 PM
I would strongly advise you to make a seperate earth connection at each side of the car, and earth each headlight (and its adjacent sidelight/indicator) seperately. The common earth, via the bullet connectors at the front, is downright dangerous as it often fails, resulting in both headlights going out. Not nice on a twisty road in a dark night.
Sepatare earths use less wire too, but I guess BL considered an extra earth bolt to cost more than a few feet of wire.
