Hs4 Hif44 Or Twin 1 1/4" Carbs?
8 replies to this topic
#1 TheOldOne
TheOldOne
  • 95 posts
Posted 25 July 2012 - 07:04 PM
Hi all
Changing engines shortly from 1098 to Metro 1275(89 model with electronic dizzy)
Standard engine no mods except lcb and k&n filters
Which carb would be most suitable? (I have all 3 to choose from)
Also is the pre verto clutch more preferential to the verto as fitted to the Metro?
All views much appreciated.
Tony
#2 freshairmini
freshairmini
  • 1,718 posts
Posted 25 July 2012 - 07:10 PM
well the 90's cooper minis had HIF44's on them. so i would sugest HIF44 purely because one is on mine being an RSP. works well, plus I think the metro's had HIF44's I think, could be wrong tho :D
#3 AVV IT
AVV IT
    I am a shed dragger.
  • 6,122 posts
  • Name: Dave
Posted 25 July 2012 - 07:17 PM
Either, it's just a matter of personal preference. The HIFF 44 will certainly be easier to set up and maintain, whereas the twins will require balancing and be a little more work. Twins are supposed to give a livelier throttle response than a single carb does though, plus you really can't beat the look of them when it comes to under bonnet aesthetics either!!
#4 oltonlad
oltonlad
  • 2,401 posts
Posted 25 July 2012 - 07:40 PM
twin carbs will give you more torque over a single carb and once they are set up they will need little or no maintenance plus they look the business under the bonnet, thats why i use them.
#5 TheOldOne
TheOldOne
  • 95 posts
Posted 25 July 2012 - 07:47 PM
Which needles would you suggest for the twins?
Also verto or pre verto?
Tony
#6 oltonlad
oltonlad
  • 2,401 posts
Posted 25 July 2012 - 07:51 PM
Tony
for a 1275 i used to use 'M' needles which worked fine, i would use the pre verto clutch as it is a bit lighter than the verto.
#7 TheOldOne
TheOldOne
  • 95 posts
Posted 25 July 2012 - 08:25 PM
Thanks for the quick replies
Tony
#8 Guest_minidizzy_*
Guest_minidizzy_*
  • Guests
Posted 25 July 2012 - 11:39 PM
The HIF44 was standard on RSP and Mainstream Cooper models but the John Cooper 'S' conversion, like on my RSP, replaced it with twin 1 1/4" carbs as part of a number of upgrades.
Edited by minidizzy, 26 July 2012 - 10:46 PM.
#9 firefox
firefox
  • 1,102 posts
  • Local Club: will find one when on the road
Posted 26 July 2012 - 10:33 PM
http://www.theminifo...hs2-you-choose/
I went for the twins as explained it is also the grin factor
Edited by firefox, 26 July 2012 - 10:34 PM.
