Edited by janner, 03 August 2012 - 09:47 AM.
Drum To Disc Conversion
janner
, Aug 03 2012 09:45 AM
2 replies to this topic
Posted 03 August 2012 - 09:45 AM
I have just converted my 1979 clubby estate to disc brakes and a servo. The brake pedal sits a bit high and the only thing stopping it from rising more is the plastic brake light switch. I dread to think what might happen if i let my foot slip off the brake -- Is this normal? - the manual doesnt help much
Posted 03 August 2012 - 10:20 AM
Have you the correct pedal box, pedal and return spring etc for your servo configuration? The Somerford Mini web site shows all possible configurations.
Posted 03 August 2012 - 11:35 AM
Well sort of, you don't need to change the whole pedal box just the brake pedal.......disc brake pedals have the lug that attaches to the master cylinder rod at a different angle.
The pedal, master cylinder and servo came from a scrap car . I cant see how i can lower the pedal as the switch is set at its longest and if i did lower the pedal by some other means -- the brake lights would be on all the time
