Reversing Light not reversing...Hazard Light not hazarding...
Posted 17 March 2006 - 12:42 PM
My hazards don't hazard aswell... caused me a bit of grief when i broke down on a round-a-bout. Wondering where the relay might be? Also i wanted to put one of those missile switches instead of the normal hazard switch...
toggle light switch...
toggle.jpg 10.19K 4 downloads missile.jpg 12.44K 5 downloads
Posted 17 March 2006 - 12:44 PM
Posted 17 March 2006 - 01:05 PM
Posted 17 March 2006 - 01:18 PM
what year is your car? my hazard relay is on the righthand side on the bulkhead
I have a 1990 mini city... but it has a 1275 in it now... if that makes a difference. I'm a bit mini experienced... what does the relay look like?
Posted 17 March 2006 - 02:06 PM
you cant do a straight swap for the hazard switch, you need to work out how isolate the indicators and basically make the 6 pins do this:
Posted 17 March 2006 - 02:26 PM
water in the rear lights maybe?
woah... hmmm so im guessing thats a diagram for the hazard switch as they are and thats how it should go with the missile switch?
Posted 17 March 2006 - 02:28 PM
Your reverse lights; the switch for these is on the box at the bottom of the gear lever (rod change minis), the wires go quite close to the exhaust so make sure they haven't melted. Also, as Neil says, check for water in the lights.
Of course, if you have a multimeter it would make fault finding easy!
Posted 17 March 2006 - 03:23 PM
Posted 17 March 2006 - 03:24 PM
Posted 17 March 2006 - 04:13 PM
You need to use relays to use a regular 2 pin switch for your hazards, and you won't get away with using less than 2/3 relays. It's not easy, believe me, getting a new hazard switch is much easier and cheaper and less likely to go wrong
indeed, 4 relays i think was my original plan but apparently you can get away with a few diodes?
Posted 17 March 2006 - 10:57 PM
I think a new hazard switch maybe the answer. (damn)
Posted 17 March 2006 - 11:12 PM
Check all your wires and fuses as above first though. Look under the carpet, the reverse lamp switch is connected just under the heater and it's easy to disconnect it with your clutch foot.
Edited by Dan, 17 March 2006 - 11:13 PM.
Posted 18 March 2006 - 01:25 PM
Of course you can use a toggle switch (stop calling it a missile switch, you sound like a chav) for hazard lights. Toggle switches are designed for industrial process control and so come in hundreds of different functions and pinouts. For the hazard switch you need a four pole double throw changeover type, get one and I'll tell you how to wire it. Hundreds of relays end up in cars because people can't be bothered to track down the right switch, the total load of the hazards is about 10 amps and a toggle switch can easily handle that. A relay is not needed. Oh, but Jammy is right it does need a telltale, which should have the warning triangle symbol on it. These are readily available from people that sell kit car parts.
Heheheh sorry... Got carried away after watching Dr. Strangelove. Will check the wires if anything.
Cheers dude!
