The part star rounding the switches on my mini sprite 1993 , how do I change it, I've looked around and I can't see anything obvious, I have a new metal one to go on
How To Change Around The Switch
chrisdeakin
, Aug 14 2012 07:03 PM
5 replies to this topic
Posted 14 August 2012 - 07:03 PM
Posted 14 August 2012 - 07:08 PM
Posted 14 August 2012 - 07:10 PM
Posted 14 August 2012 - 08:41 PM
- Drop heater to provide access
- Disconnect choke from carb
- Disconnect heater cable from control valve
- Pull switches out of panel
- Disconnect wiring from switches - label for replacement
- Undo retaining nut for choke cable - withdraw cable
- Undo retaining nut on heater control - withdraw cable
- Undo retaing nuts on switch surround - remove panel from dash
Re-assembly is a reverse of above.
Posted 14 August 2012 - 09:38 PM
... Sounds a big job for a little change haha, any one want to do it for all the tea they can drink ? ;)
Posted 14 August 2012 - 09:41 PM
It dosnt sound big, just time consuming, I am sure you can manage it :)
