I don't agree and I'd go with either a SW5-07 or a Piper BP255 . Cam technology has advanced in the last 40 years and they are essentially updated 998 cooper cams. Beating a SW5 for torque is reaaaaly hard in my experience.. unless you go turbo. Duration wise it is actually quite short (244 isch !) but I think they did not name it after the duration because people are stuck on cam duration as the only parameter for cam performance.
I would budget for a good rolling road setup from the get go. ( check out the checklist from emerald3d to highten the chances that you are not trouble shooting instead of setting up while you are on the rollers
If you can stretch the budget a small bore ST3 head from (keith) www.calverst.com would be an excellent choice. Otherwise i'd just stick in the Minispares bigger valves and spend the money on the valve seat job and some minimal chamber work so the bigger valve can actually flow more.
If the budget is still too tight for that just get the seats recut (you can chase that for decades but in this case a two of three angle seat would work fine.. and even a super wide stock seat is not all that bad as long as you backcut the intake valves to 30 degrees so that the 45 degree part is about 1.6mm wide. That gains a relatively huge amount of flow for the work and cost involved. The exhaust valves don't need it really. A tiny bit of cutting to the chamber is not much work either
hope this helps a bit.
Edited by Sir Yun, 03 October 2012 - 05:38 PM.
