Very interesting topic, as I have started a very simular engine build !
My goal is to create a smooth running modded 1100 for my Mini estate project,
so no streetscreamer spec's but all the mods and nice goodies are focussed to get more torque, and drivability.
Although...once started, I could not resist the temptation, and had my crank wedged and balanced
At this moment I have all the parts in house and I am planning to build the engine during the dark December period.
My spec's:
pre A+ 1098cc +.060"" (1150cc)
Calver ST small bore stage 3 cylinder head, 30.94 inlet / 26.42 exhaust valves
Swifttune SW5-07 cam
MED big shaft 1.3 roller tip rockers
Duplex vernier cam gear / chain
Calver ST 1098 piston set +0.060", CR 9,5
Lightened & balanced std. conrods / wedged & balanced crank / (little bit) lightened & balanced flywheel
H&H 65DM4 full electronic distributor and coil kit, modified advance curve
inlet manifold Howley 1"3/4, HS4 carb
Small bore LCB exhaust + RC40
3.1 Final drive ratio
I will be following this thread
Edited by Innodetomaso, 03 December 2012 - 05:59 PM.
