Whats Needed For A Service And Freshen Up?
conlad
, Aug 17 2012 08:08 PM
9 replies to this topic
Posted 17 August 2012 - 08:08 PM
The mini hasnt been started properly since earlier this year and I am going to freshen her up before the MOT which will hopefully be soon as my test is booked for late this month!
I am thinking
New oil
Oil filter
Need to bleed brakes and clutch too
Plugs
HT leads??
Dont want to spend a lot as I am literally skint!
Got a mate who is a proper mechanic and will do this with me but I need to get parts for it all
What else should I do to ensure it starts and idles well?
I am thinking
New oil
Oil filter
Plugs
HT leads??
Posted 17 August 2012 - 08:10 PM
Air filter. If its a K&N, I'm sure it'll be fine as it is, however.
While you're at it, check your brakes over too. Take the front wheels off and how much pad material is left. Do the same for the rear drums, then adjust properly. You'd be reet pissed off if the car fails on something as simple as brake effort.
Edited by minimissionary, 17 August 2012 - 08:13 PM.
Posted 17 August 2012 - 08:11 PM
Got the K&N already in there so thats all good!
Posted 17 August 2012 - 08:14 PM
Nearly done now then?
New point's, rotor arm and dizzy cap.
Check the timing and tappet's.
Posted 17 August 2012 - 08:18 PM
timing, points and condencer, plugs if you fancy.
and grease everythin for the mot!
Hmm not quite but I need her running or there is no point doing anything else
Oh ar yeah I need to do timing definately
Dizzy cap. Coolant.
Edit: Beaten to it!
Edit: Beaten to it!
Edited by minimissionary, 17 August 2012 - 08:19 PM.
Posted 17 August 2012 - 08:19 PM
What would be involved with points and condenser??
Posted 20 August 2012 - 11:51 PM
unscrew the old one, unplug it, whip it out and put the new ones in, then check your gap and adjust if neccacery, all you need is feeler gauges and a flatty :)
Posted 20 August 2012 - 11:56 PM
if it isnt running i would be check :air filter filement, carb and timing , and renew as neccacery
and work your way through the problems from there so you dont waste time and money replacing bits twice or bits that are ok :)
most of a standard service can weight untl after the mot as you dont want to have paid 30 quid to do all your oil and need it for a set of barings etc
