Does anyone know if you can fit a Hayabusa engine under the bonnet of a standard round nose without cutting out the toeboard/bulkhead and losing all of our feet room? Similar to what SukiDawg is going to do with a R1.
Thanks, Bert in USA
Hayabusa - Front Engine, Rear Wheel Drive?
Bert66
, Aug 18 2012 03:00 AM
5 replies to this topic
Posted 18 August 2012 - 03:00 AM
Posted 26 August 2012 - 03:00 AM
http://www.motorspor....uk/minir1.html
Not sure how much bigger the Hayabusa block is than the R1but, I think it would be possible.
Posted 26 August 2012 - 07:20 AM
I thought you could only do it with the R1 engine as its very compact!
That's only what I've read though so I may be wrong
Posted 27 August 2012 - 02:02 AM
Even looking closer at the link I posted his "grill"has his exhaust running through it. It might be a tough one.
Posted 28 August 2012 - 11:41 AM
Thanks, Bert in USA
No you can't, it will need some surgery somewhere to get it all in, even an R1 which is tiny in comparision to a hayabusa is an extremely tight fit
David
Posted 27 September 2012 - 07:08 PM
Also, front engine RWD is the worst combination for powertrain layout in a Mini
