sump plug
Posted 19 March 2006 - 04:36 PM
Posted 19 March 2006 - 04:39 PM
They should undo with a normal socket (unsure of size) if not get a bit of leverage with a bit of metal tube.
Have the container to catch the oil in ready, and undo the last couple of turns by hand and keep it pushed into the hole.
and watch out for oil going up your sleeve lol
Posted 19 March 2006 - 05:00 PM
Posted 19 March 2006 - 05:17 PM
Posted 19 March 2006 - 05:23 PM
then big arse ajusty spanner and take it out. from the front of the lay on the floor so your head is toward the left of the car. big bolt down there.
i know this is sumone elses thread but my sump plug is leakin,it is tight,could it be the metal washer??
clear it all off the oil that is. then stick a bit of paper end the plug on the floor. leave it underneth then cheack again to see if it is leeking. if it is then look to see if you put the washer on. its either brass or copper. i think you can also get plastic one. if you can take the plug back out and see if the washer looks mangled and batted up. if so replace it. if not then it could be the thread in the sump.......in which case i have no idea what to do but someone will.
Posted 19 March 2006 - 07:22 PM
Posted 19 March 2006 - 07:43 PM
Posted 19 March 2006 - 08:52 PM
You don't need to remove anything else such as engine steadies. There is nothing else in the way. You should just be able to remove it using a socket and normal ratchet. To loosen it you will need to pull the ratchet up towards you. (I only remember this as I ALWAYS end up smacking my forearm off the front panel!!!!!)
It's not a difficult job. Make sure you have a container ready and make sure the engine, and therefore the oil, is warm. It often helps to jack up the passenger side of the car too.
Don't forget to change the oil filter at the same time.
Posted 19 March 2006 - 09:05 PM
Posted 19 March 2006 - 10:58 PM
No, no, no, minis do not use sockets or spanners in mm.
Sometimes they do. The designs been changed a lot in 41 years and lots of the later parts are metric. You need both to work on Minis.
Posted 20 March 2006 - 02:43 AM
As for the leak.... I have switched to a bonded rubber/metal seal on my car (MotorMite part number 365269) This is a metal ring with a thicker rubber ring in the center. It's officially a 14mm seal but it works wonderfully. You snug up the drain plug and it seals without excessive torque. These are ideal if you've got a scored or otherwise damaged sealing face on the sump. If you can't find these, supply houses over here sell ribbed nylon drain plug washers (also 14mm) that also work well. I'm sure you'll find similar products in the U.K.
Posted 20 March 2006 - 09:05 AM
Posted 20 March 2006 - 11:22 AM
Posted 20 March 2006 - 11:34 AM
I believe it is 24mm if that helps.
thats right but i am sure it supposed to be the imperial equivelent
Posted 20 March 2006 - 11:45 AM
Use a uni part oil filter.
