Hi everyone, I’m new here, and have a quick question which I just hope is not as stupid as it sounds.
I am waiting for my MG Metro Turbo to arrive, which hopefully will be this Tuesday, on a transporter from Wales to Oxford, and am not sure whether it will run on unleaded or not ?.
Many thanks in anticipation
Malc
P.S. I hope that I have found the correct forum as my searches have come up blank for this particular model.
WHICH FUEL ??????
Malc
, Mar 19 2006 06:48 PM
7 replies to this topic
Posted 19 March 2006 - 06:48 PM
Posted 19 March 2006 - 07:28 PM
it depends on how old it is dude. You'll need to check the first part of the engine number or take the head off and inspect to be sure.
MG Metro Turbo - leaded fuel pre 1989 - 1275cc - 12HD26
MG Metro Turbo - unleaded - 1275cc - 12HF01
Posted 19 March 2006 - 09:02 PM
Many thanks bud666
It is an 1989/G so it looks like I might still be sweating till it arrives :'(
Posted 19 March 2006 - 10:28 PM
Where in oxford malc??? i'm in witney!!!!
if it is a lead head don't panic, there's loads of additives you can use... failing that, when you are rebuilding it (once a month) you could get hold of one of the later heads and fit that.... make sure it's the turbo head though because the compression is much lower.
Posted 19 March 2006 - 10:34 PM
That’s where I was working last week, (Witney) I’m right on the Oxford ring road at Rose Hill/Littlemore.
Malc
P.S. I hope I wont be rebuilding!! :'(
Malc
Posted 20 March 2006 - 03:11 AM
the only difference on the turbo heads is the 8mm stems on the exhaust valves, it still ran quite a high compression ratio at 9.4:1
But not to worry if it is leaded, i'd recommend castrol valvemaster plus from halfords. just stick normal or super unleaded in and the additive will protect the seats and also boost the octane by 2 points
Posted 22 March 2006 - 12:21 AM
is there anything wrong with using say opitipax, or tesco finest petrol (99RON) in a normal 998 with a stage 1 kit?
Posted 22 March 2006 - 12:39 AM
What? other than it still being unleaded requiring addative?
