70 Amp Alternator Question
Posted 26 August 2012 - 05:34 PM
Posted 26 August 2012 - 05:36 PM
Posted 26 August 2012 - 06:01 PM
Posted 26 August 2012 - 06:11 PM
Posted 26 August 2012 - 06:28 PM
what gauge wire should i use
you think the alt would of came with instructions saying to do this lol
Posted 26 August 2012 - 06:37 PM
http://www.theminifo..._hl__alternator
Posted 26 August 2012 - 07:05 PM
and the reason to take it to the solinoid is because thats where you battery positive cable goes to, and where all your power comes from.
Posted 26 August 2012 - 07:28 PM
Be very, very sure that the terminals are properly crimped to the wire, as if one fails with the engine running you are vety likely to destroy the alternator. Do not use a cheap crimp tool.
Your cable should be 80/0.40 mm, preferably brown, and is available here:
http://www.autoelect.../66/category/11
Posted 26 August 2012 - 07:58 PM
Posted 26 August 2012 - 08:06 PM
Posted 26 August 2012 - 08:21 PM
If its anything like my one from an age back, its a stereo wire to stop feedback.
Stereo wire to stop feedback?? What are you talking about?
Posted 26 August 2012 - 10:12 PM
Please ignore bad advice. You should run a single 70 amp wire, not multiple thinner wires, which will not current share properly, and a "stereo" wire is pure nonsense. Sadly we often get this sort of stuff where electrical problems are concerned. It goes to the starter solenoid because the main battery feed to that point is more than capable of carrying 70 amps.
Tiger you've been right about this sort of stuff in the past so i trust what you say but i just want to make absolutly clear your talking about the spade connector yeah? not the post conector eeae is talking about? as far i know nothing connects to the post conector?
the reason i ask is because i've just bought a new 70amp alt and i was stumped as to what connects to the spade conector as there wasn't anything on the older type alt.
with regard surpressors i thought they were built into modern alts nowerdays, or am i wrong?
trac
Posted 26 August 2012 - 10:14 PM
Thought it might of been the same thing, stops stereo making odd noises. Never had a stereo, so never bothered with it.
Posted 26 August 2012 - 10:46 PM
The usual 3 spade plug...small and 2 large...small being the ignition light , the 2 large being outputs. I could be wrong but I think these are joined inside anyway.
And also I had a seperate 6mm threaded lug which is also an output.
The 2 large spades and 6mm lug do the same job, just different fittings.
It's worth double checking with a multimeter , because I seem to recall theres another threaded lug which is earth, wouldn't want connect that to the battery.#
Going back to what Tiger said about multi cables, Pretty sure my mini had 2 brown wires coming from the 3 spade terminal going to the solenoid. And Haynes shows 2 in the wiring diagram.
Threaded lug top of picture (B = Battery) that and the 2 large spades which are also B terminals
Edited by lrostoke, 26 August 2012 - 10:50 PM.
