70 Amp Alternator Question
36 replies to this topic
#16 tractor
tractor
  • 662 posts
Posted 27 August 2012 - 10:37 AM
if you want to see the inner workings of the a127 alternator check this video out
its a guy rebuilding one
#17 tiger99
tiger99
  • 8,584 posts
Posted 27 August 2012 - 11:36 AM
That is superb!
#18 brad-the-bear
brad-the-bear
  • 1,114 posts
Posted 27 August 2012 - 12:37 PM
Please ignore bad advice....
who is giving the "bad advise"?
#19 tiger99
tiger99
  • 8,584 posts
Posted 27 August 2012 - 01:02 PM
I would have thought that was obvious, but you were not the only one.
#20 brad-the-bear
brad-the-bear
  • 1,114 posts
Posted 27 August 2012 - 01:20 PM
how was it bad advise? i was simply giving you a cheap but EFFECTIVE resolution to your problem.
#21 jonny d
jonny d
  • 1,148 posts
Posted 27 August 2012 - 05:47 PM
what a great video that was I could do that now
#22 tiger99
tiger99
  • 8,584 posts
Posted 27 August 2012 - 06:18 PM
Cheap, largely ineffective, and a fire risk. The wires will not share current properly, as the odd milliohm of contact resistance at the terminals will make one take almost all the current.
#23 lrostoke
lrostoke
  • 6,923 posts
Posted 27 August 2012 - 06:36 PM
See I'm confused by that because the Haynes wiring diagram does show 2 wires coming from the alternator B+ terminals to the solenoid.
Pretty sure mine as 2 as well
Thats 2 on top of the ignition light wire
#24 tiger99
tiger99
  • 8,584 posts
Posted 27 August 2012 - 07:28 PM
Well, if so, they will not share current properly, for the reason I gave. That is not quite so serious for a 35 amp alternator, but 70 amps increases the risk.
#25 brad-the-bear
brad-the-bear
  • 1,114 posts
Posted 27 August 2012 - 07:36 PM
the terminals are made to share 70amp? what's it got to do with the terminals?
#26 eeae6000
eeae6000
  • 328 posts
Posted 27 August 2012 - 07:40 PM
so should i connect a large diameter wire to the battery 6mm post or is the 3 spade connectors enough
#27 l_jonez
l_jonez
  • 1,453 posts
Posted 27 August 2012 - 07:54 PM
I ran mine with the standard connection with no problems, I'm pretty sure the spi had a 70A alternator and the same wiring ?
#28 tractor
tractor
  • 662 posts
Posted 27 August 2012 - 08:01 PM
i've just been out and had a look at my loom, i've got a 1976 MK3 loom, all that connects to the alternator is the standard plug we all recognise, coming out of that plug is the centre thick brown wire which goes to the solenoid, separate to the starter in my case, then one side theres a brown and yellow smaller wire that connects to the dash as the ignition warning light and the other side theres a brown and blue wire that also goes to the solenoid but it thinner than the centre brown wire.
heres hows it depicted,
what do the initials stand for i'm guessing the + represents that battery but what do the other two mean?
#29 tractor
tractor
  • 662 posts
Posted 27 August 2012 - 08:03 PM
i recon i'm gunna use both outputs of the alternator so the standard plug i've already got and i'll make a wire to connect the post to the solenoid as well,
can't do any harm can it? someone tell me if i'm wrong please
Edited by tractor, 27 August 2012 - 08:05 PM.
#30 brad-the-bear
brad-the-bear
  • 1,114 posts
Posted 27 August 2012 - 08:09 PM
IND is for Indicator and i was always told "s" on an alternator was for voltage sensor?? anyway both the two big spade terminals go to the solenoid
EDIT: be sure to check your wiring diagram as things may differ.
Edited by brad-the-bear, 27 August 2012 - 08:10 PM.
