well i would say if your fitting a 3.1 diff then go for a 266 cam other wise it will be difficult to keep on cam
+1 on that.
Posted 30 August 2012 - 08:47 PM
Posted 30 August 2012 - 09:08 PM
Posted 31 August 2012 - 07:17 PM
Posted 31 August 2012 - 07:46 PM
Cheers for the advice guys, I've got the complete spec if it helps
Spec -
1275 A+ block, bored to +40
Mini Sport road sport head (37mm inlet, 29mm exhaust, double valve springs, gas flowed, ported & polished)
C-AJJ3378/40 Pistons (from minispares ctr)
Balanced metro turbo crank
Centre main strap
Duplex vernier timing gear
HIF 44 or Twin HS2's
Maniflow LCB
RC40 twin box system
I've also got 1.5-1 ratio ratio rockers, would they be worth while fitting if I've got an aftermarket cam?
