Hi I've managed to get hold of. A plus 40 block 998 but I currently use a plus can I use my a plus parts on a series short engine ??
A Series And A Plus Interchangeable ?
minimanjay
, Sep 11 2012 02:43 PM
6 replies to this topic
Posted 11 September 2012 - 02:43 PM
Posted 11 September 2012 - 02:50 PM
You can't use the distributor, but everything else is more-or-less the same. The alternator bracket is also different as it's shorter.
The transfer gears are different, but just use your original primary and transfer gear and it'll be fine.
Posted 11 September 2012 - 02:55 PM
Dip stick ?
Posted 11 September 2012 - 02:59 PM
I thought u could use the transfer gears if u use the a plus side cover ? And could I not use the dizzy if u use my a plus dizzy drive ?
Posted 11 September 2012 - 03:06 PM
Yes, so long as you also change the geabox input gear and the transfer gear case.
The distributor drive is totally different from A to A+.
Posted 12 September 2012 - 08:21 PM
You might want to try this http://www.minispare...|Back to search
