My front subframe on my Cooper SPi has cracked at the front. I'm now in urgent need of a new subframe for it.
I realise that I can't use a carb mini subframe as the block is 3/4" further forward on SPi's, but can I use one from an MPi? Are they exactly the same?
Thanks. Guy.
Front subframe differences
gsms
, Mar 23 2006 06:06 PM
8 replies to this topic
Posted 23 March 2006 - 06:06 PM
Posted 23 March 2006 - 06:31 PM
i think they are the same but have mounting points for the front mounted rads.
Posted 23 March 2006 - 07:25 PM
ditto, as far as i am aware just the front rad mountings, so a swap shouldnt be a problem.
Posted 23 March 2006 - 07:38 PM
Excellent. Cheers guys.
Posted 23 March 2006 - 07:40 PM
You can use a standard one and redrill the holes. And its more like 10mm
Posted 23 March 2006 - 09:01 PM
Ah right! I didnt know that, sprocket, thanks.
Instead of spending half a grand, what about getting it welded back together? It's a clean, vertical split, and at a point near the tie-rod which is only about 6 cms wide, and would cost £30 rather than £500?
Posted 23 March 2006 - 10:11 PM
They are out of stock, I know, but how much did you say!
http://www.minispare....aspx?pid=33332
Personaly Id replace the whole thing with a new or second hand item
Posted 23 March 2006 - 10:23 PM
hmm, so maybe I overestimated a little bit! But I don't have the time right now to fit it, or have the money to GET it fitted. Would a professional welder do the trick for atleast a while do you think?
Posted 23 March 2006 - 11:04 PM
You have my recomentation, that is all i will say about welding it.
