Hi,
I am looking to get more power out of my mini with a budget of £750.
My mini is fitted with a M.G metro 1275 which has a 276 cam hif44 carb,1.5 roller tip rockers,larger valves,raised compression, LCB manifold and exhaust.
Can anybody help?
1275 Tuning!
minicity1275
, Sep 24 2012 08:58 PM
2 replies to this topic
Posted 24 September 2012 - 08:58 PM
Posted 24 September 2012 - 09:36 PM
with that spec (if it has been built properly) you should be seeing 80-85bhp, how much power do you need? i would think thats plenty of power for a fast road mini, you say larger valves........larger than what? MG metro ones? i guess you could put a pair of HS4's on it to release more power but the key to an A series's power is a well built and flowed cylinder head, there is no point in slapping bigger valves in a head that still has standard ports!
Edited by oltonlad, 24 September 2012 - 09:38 PM.
Posted 25 September 2012 - 07:00 AM
As this is in the forced induction section, I presume that you are really asking if £750 will be enough to get your car a turbo.
I can answer that in one word, no.
You'll need double that to do it really. I managed it on £1k, but I already had parts hanging around to use.
