Banging Noise When Clutch Is Pressed
#16
Posted 07 October 2012 - 03:15 PM
#17
Posted 07 October 2012 - 03:27 PM
Looks like its the next thing for me to do.
Edited by Nick Warwick, 07 October 2012 - 03:28 PM.
#18
Posted 07 October 2012 - 03:29 PM
check the top engine steady bar.
Already checked it isn't the steadys
#19
Posted 07 October 2012 - 04:20 PM
You need to support and slightly jack up the engine on the clutch side from under the gearbox (use a bit of wood between the casing and jack) then undo the engine mounting on that side. Then you can undo all the clutch cover bolts.
Once off you can have a look at the clutch and the release bearing.
#20
Posted 07 October 2012 - 06:12 PM
#21
Posted 07 October 2012 - 07:25 PM
It happens while driving and stationary too. I did notice earlier it made the noise while I cranked the engine over then stops after a few seconds.
#22
Posted 07 October 2012 - 07:33 PM
#23
Posted 07 October 2012 - 07:34 PM
i would start with checking the length of the bolts holding the clutch slave cylinder/bracket in place
Or the engine mounting ones.
#24
Posted 07 October 2012 - 07:39 PM
#25
Posted 07 October 2012 - 08:12 PM
If they were the problem I would have thought the knocking would have been present a while ago.
I could have got the bolts mixed up while I had the engine out but like I said above the knocking would have been present earlier?
Edited by Nick Warwick, 07 October 2012 - 08:13 PM.
#26
Posted 07 October 2012 - 08:16 PM
It is still looking like the release bearing, although they don't usually make that kind of noise.
#27
Posted 08 October 2012 - 10:20 AM
Just a list of things i have done:
Supercharger kit added
x-pin diff
cylinder head replaced
I do know that some people had the same problem as me when fitting the supercharger it creates a flat on top of the exhaust branch under it (making a knocking noise for a while until it's beaten flat). I don't think this is the problem but i thought it would be worth saying.
#28
Posted 08 October 2012 - 03:10 PM
What Compression ratio is the new head skimmed to?
#29
Posted 08 October 2012 - 08:31 PM
22cc from what i remember
#30
Posted 09 October 2012 - 09:29 AM
