Howdy.
Got a 998 and going to fit a freeflow exhaust manifold with rc40 exhaust.
Problem is the standard inlet and exhaust manifolds are cast as one piece.
So I need to either buy a inlet manifold... or cut the old one.
I've heard of people doing this. I dont care how hard the material is to cut as we've got pretty much any tool to do it. What I want to know is if I do separate the manifolds...
1) Will the Inlet be left with enough material where I cut it?
2) Will I gain enough clearance between the exhaust manifold and inlet?
I know inlets arn't all that expensive and would be easier, I just want to know my options for my bdget build.
Any help is appreciated.
Cheers!
Is it possible
jack_marshall
, Mar 25 2006 12:06 PM
7 replies to this topic
Posted 25 March 2006 - 12:06 PM
Posted 25 March 2006 - 12:38 PM
i tried doing this and you have to be very careful but it is possible.
i went through mine though!!
i will get some pics if you want
In general terms yes it can be done, but the time and effort needed to do it out strip the cost of an alloy manifold quite a few times over. plus they are a better shape.
Posted 25 March 2006 - 12:40 PM
i think jam2005 had one for sale
Posted 25 March 2006 - 05:33 PM
Nah, he hasn't, just asked him.
Ah well, Ill look out for a cheao one and if that fails ill have a go at cutting it.
Is there any specific I should be looking for? Its a standard 998 with what I presume is a 1.25 carb.
Posted 25 March 2006 - 05:47 PM
http://www.minispare....aspx?pid=35083
im guessing you'll get better performance from your exhaust with one of these anyway.
if you havent already bought the exhaust, then just buy a stage 1 kit. comes with everything you need and its cheaper to buy it in one go.
Posted 25 March 2006 - 10:07 PM
if you do get an alloy inlet manifold , be carfull when fitting as often the flanges on the inlet are thicker than the exhaust flanges....
i used 1/2 washers to take up the difference.
mark
mark
Posted 26 March 2006 - 01:36 PM
if youre not using the exhaust part, then cut as far away from the inlet part ass possible to make sure you dont break through to the ports,the use an angle grinder etc to remove the excess. you could always port it aswell to make it flow better.
