Im having my engine out soon to have a SW5 cam fitted and was thinking. While its out, is there anything i can do to my standard gear box to make motorway cruising a tad more friendly on my engine? Maybe a different box is needed, but if its possible id like to get away with the standard box.
Its a 1995 SPI, Im quiet happy to put some money into this as it 'should' extend the life of my engine.
Bounce
Gearbox suggestion?
Bounce
, Mar 25 2006 08:51 PM
12 replies to this topic
Posted 25 March 2006 - 08:51 PM
Posted 25 March 2006 - 09:26 PM
you could change the diff so it is better for motorway cruising
Posted 25 March 2006 - 09:40 PM
Any ideas? I have no knowladge about diffs, only a very basic idea of how they work.
I was thinkin changing ratios on the gearbox to keep the revs down, maybe even shelling out for a 5 speed box
Posted 25 March 2006 - 09:42 PM
you could fit the 2.7:1 final drive from the likes of the MPI. Im sure there is some one with one they dont use and have lying about.
Posted 25 March 2006 - 09:44 PM
Sorry, im a leckie, i dont do engines. are you on about gearbox or diff?
Posted 25 March 2006 - 09:49 PM
the 2:7:1 is the final drive ratio of the diff, it should help on the motorway.
Posted 25 March 2006 - 09:53 PM
Cheers for the help guys
Posted 26 March 2006 - 06:30 AM
I would go 2.95 minimum, unless you have a seriously torquey motor 2.7's just kill any acceleration you once had... I think the SPI's have 3.1's as standard which is not such a bad diff ratio anyway...
Posted 26 March 2006 - 12:54 PM
agreed a 2.7ratio will kill your acceleration, its what i have fitted to my mpi, i dont generally thrash about anyway so acceleration aint a problem, it still goes enough though, while on motorways it is quite quiet at 70mph ( well for a mini anyway)
Posted 26 March 2006 - 12:55 PM
i think my old spi had a 3.44... 70mph @ 4k so id check first, my car was a k reg
Posted 26 March 2006 - 01:04 PM
I get around 70 @ 4k not fantastic for the motorway. I like my acceleration, but i drive on the motorways a fair bit, is there an in-between soulution??
A 5th gear perhaps?
A 5th gear perhaps?
Posted 26 March 2006 - 01:07 PM
i would think a 3.2 would be better for u, i want to have one when i get my new engine. only problem u will have is to recalibrate your speedo.
